Forums › The Car › 206 Talk › How to Bleed Engine Coolant |
Posted: Sun May 15, 2011 8:48 am |
206-GTi wrote: |
There is a tap at the bottom of the radiator. You can bleed it all from there.
Adding new coolant is a different story. of course you want to pour it in the resovor. Just make sure you bleed all air out of the system.
How can you bleed it from the bottom of the radiator? You can drain it from there but bleeding needs to be done from the highest points!
On the GTi and I imagine other are the same there is a bleed screw on the thermostat housing and one on the heater hose where it goes through the bulkhead.
