Latest: heikkisj
Overall: 17126
Online Now [68]:
Visitors: 67
Today: 19727
Total: 100256013
Forums › The Car › 206 Talk › Air , hissing noise coming from coolant tank
Go to page Previous  1, 2, 3, 4
bigtony85
PostPosted: Sun May 15, 2011 2:49 pm Up
shine a torch in to the header tank and u will b able to see the level clearer
drive fast !!! live life faster !!!
eddrj
PostPosted: Sun May 15, 2011 2:58 pm Up
Cartoonhead the other screw i think is at bottom mid near radiator on and by thermastat its not in exact place as urs is it because mines a 2000 i actaully havent got bleed screw in same place heater matrix yeah but other is different place .Or i only have one bleed screw ? looks like one at end of thermastat mid in middle of radiator not right habd side like in your pic .
I just tries that still cant see level atall and its a bright good torch , this coolant bottles are s**t why they make it so hard meant to be easy checking coolant level . there's gotta be a easy way surely and the joke is if you fill it so you can see it thats a fair bit over max .
Would it hurt it much being bit over the max level ?
And its 50/50 water, coolant rite ?
Old car 2000/ 206 2.0 hdi.
bigtony85
PostPosted: Sun May 15, 2011 3:04 pm Up
it should just spew any excess coolant out
yeh most coolants 50/50
eddrj
PostPosted: Sun May 15, 2011 3:05 pm Up
ok thanks
so should be fine to put bit more in over max ? ,
so i can at least see it better than none in there suppose because its the only way i can see if there's any in there .
bigtony85
PostPosted: Sun May 15, 2011 3:09 pm Up
yeh wont kill it if there's too much in it it should spew it out of an overflow and get its own level.
eddrj
ok cheers
eddrj
PostPosted: Mon May 16, 2011 12:54 am Up
Think its sorted i did the other one tiny bit tight it back up,
topped up coolant and think its done the trick seems ok now ,
not making noise after 2 quick trips in my car for a test run .
mattievrs
PostPosted: Mon May 16, 2011 3:27 am Up
Id buy a new coolant tank lid mate. Sounds like the seal has gone in it. The caps are also self bleeding so you shouldnt have air in the system.
NO LONGER ACTIVE ON THE FORUM
eddrj
PostPosted: Mon May 16, 2011 5:39 am Up
ok , i ordered one last nite cause there only bout £6 .
Hate the way you just cant see in the damn coolant tank it must be the most stupid thing about the 206 lol .
PostPosted: Mon May 16, 2011 5:54 am Up
The system isn't self bleeding, that's why it has bleed screws fitted.
eddrj
PostPosted: Tue May 17, 2011 1:44 pm Up
also got new coolant lid def needed new one,
because new one feels so much more tight and better can feel the 15 psi if you get what i mean before was just a bit tight .
Page 4 of 4
