Posted: Tue May 17, 2011 2:20 am |
Alright guys, well i the 206 gti i had i sold to my brother, and he has had an accident in it.everyone was fine and there's not too much damage to the car. but a few parts will be needed to get it back to its best.
1. airbags down the passenger side went off and from the steering wheel, how much do these cost?
2. boot is slightly misaligned, will a new one be required or cud be sorted?
3. dents in the back passenger panel, not too bad but a new one will eventually be neeeded, how much are these
the car is augean blue, anyone selling or no anywhere to get the parts cheap?
cheers
Posted: Tue May 17, 2011 2:25 am |
depending on the damage you might need to get a body shop to put it on a jig.
| *DEAD*206 Gti 138
Toyota Celica T sport 205 BHP | |
Sounds like a write off to me.
Would most likely be cheaper to get a new car than repair this one.
Posted: Tue May 17, 2011 2:29 am |
Airbags going off are never good.
If you tell the insurance comapny, pretty sure they will write it off.
Whos fault was it?
| Peugeot 206 1.4LX - Sold
Vokswagen Bora 2.0 - Sold
Seat Leon MK2 2.0 TDI - New
Posted: Tue May 17, 2011 2:37 am |
pics?
Posted: Tue May 17, 2011 2:38 am |
The airbags and dash will cost you £600 each and £40 for dash plate. And you will need to get a new airbag sensor cause new airbags won't be recognised by another airbag sensor.
I crashed mine and blew air con along with air bags they wanted £1000+ for aircon and £1200+ for airbags it will have probely bent some part of the support so re jig your looking £100 at least and no doubt you will need a new support beam costing around £80
Not cheap If But your lucky you got rear smash shouldn't cost too much part from airbags
| F**k Scene YAWN
Project GreenMachine: 206info.co.uk/Forums/v...rt=75.html | |
Posted: Tue May 17, 2011 2:39 am |
it was only my brother in the accident, he hit a roundabout so no other cars involved. yeah i said the insurance would write it off, but hes determined to get it all sorted.
Posted: Tue May 17, 2011 3:50 am |
if the actual frames bent your screwed other then that look at scrappys etc
Any work you undertake as a result of my posts is done so at your own risk | |
Posted: Tue May 17, 2011 12:35 pm |
buy another gti, cost well less than fixing yours.
unless you can fix it yourself. airbag could get a second hand one.
but the rear 1/4 panel and boot will have to cut off and weld a new one on. <--not cheap.
check if the axle is bent as well.
