Forums › The Car › 206 Problems › long drive ahead. |
Posted: Sun May 08, 2011 11:42 am |
jedwards wrote: |
MrBSI wrote: |
jedwards wrote: |
do you know of any good degreasers as it could still have quite a lot of oil in the system maybe? |
NON bio washing up liquid / powder or dishwashing tablets.
MUST be NON bio
Couple of tablets added to the expansion bottle when cold & take the car for a drive to get it nice & hot, smells lovely & also cleans all the crap out the cooling system at them same time better then stuff you can buy on the shelf. |
awesome! will it need flushing afterwards? |
Rise it out with water from the hose before putting all the pipes back on.
Posted: Sun May 08, 2011 11:54 am |
If it's had a new radiator and thermostat, other than replacing the temp sensor I would also think it must be the water pump. Unless the head gasket was fitted incorrectly.
Posted: Thu May 19, 2011 11:56 am |
ok so ive just taken my front bumper to look at the wiring on the fan and found that 1 prong on both of the relays has corroded and snapped, wondering if you can replace these or do i need a whole fan unit? also could this be why my fan kicks in at 103degrees and not 93 like a lot of people on here are saying?
