Posted: Fri May 20, 2011 1:21 pm |
I AM SICK TO THE BACK BLOODY TEETH!!!!
Tracking keeps going out.
IN January my steering wheel was shaking badly, took to local garage, needed 2 new front tyres as they were mis shaped. (they had been on about 5 years) this solved the shaky steering wheel, all was fine...UNTIL about a week later when tracking when out, took back to garage who said the tyres take a while to settle so re traced for free and ever since then it's been a nightmare.
The tracking keeps bloody going out!!!!
IN march the garage changed my steering rack end as said there was slight play on it - all was fine again until about a week after when the problem started again.
I must of had the tracking done 15 times since January and the wheels re balanced god know how many times.
Ive been to 3 garages and none seem to know what it is. I need my car for my job and need it to be reliable but to tell you the truth I don't feel safe in it at the moment especially on the motorway at high speeds.
Smeone give me some ideas please
Posted: Fri May 20, 2011 1:22 pm |
wishbone and trackrod end.
Posted: Fri May 20, 2011 1:23 pm |
They aren't kwik fit / halfords style garages are they?
Posted: Fri May 20, 2011 1:25 pm |
No local independant ones
Posted: Fri May 20, 2011 1:26 pm |
track rod end is that not the same as steering rack end?
and which parts are the wishbones
Posted: Fri May 20, 2011 1:28 pm |
has any of them even bothered to check the front Ie wishbones, wheel bearings, top mount bearings ?
alloys could be buckled? Check the wishbone bushes for splits etc. Possibly top mounts?
Posted: Fri May 20, 2011 1:33 pm |
Alloys are new only got them last week - kinda hoping they would solve problem but haven't the garages have all said they have checked everything and found nothing.
i am going to take it peugeot in monday (having to take time off work!) and ask them, I will suggest the wishbone and track rod to them. I didnt want to go there as i know they aren't cheap but if they can get it fixed then its worth the extra i suppose
Posted: Fri May 20, 2011 1:38 pm |
Only fit GENUINE Peugeot parts on the front suspension, total waste of time & money fitting anything else
Posted: Fri May 20, 2011 1:41 pm |
MrBSI wrote: |
Only fit GENUINE Peugeot parts on the front suspension, total waste of time & money fitting anything else |
yes i will bear that in mind!
Posted: Fri May 20, 2011 1:49 pm |
how much u think it will cost to replace those?
Posted: Fri May 20, 2011 1:52 pm |
alanamh wrote: |
how much u think it will cost to replace those? |
You need to find out exactly whats wrong with it before you replace any parts.
Just throwing new parts at a car in the hope of fixing a problem just ends up with a large dent in your wallet.
Posted: Fri May 20, 2011 1:54 pm |
I know but just say it was those would it be expensive?
Posted: Fri May 20, 2011 1:56 pm |
alanamh wrote: |
I know but just say it was those would it be expensive? |
If a Peugeot main dealer was fitting them then yes due to there labour charges for fitting.
