Online Now [601]:
Visitors: 599
Bots: 2
Today: 97909
Total: 155577954
Forums › The Car › Request a how-to › remove multiplexed steering wheel and others
rudymason
PostPosted: Sat May 21, 2011 2:51 am Reply with quote Up
Basically i have a few queeries and am struggling to find any info so thought id post a thread to get peoples know how !!
Im wondering firstly how to remove the steering wheel
-how to update a non fog light bumper to a front bumper with fogs?
(basically wondering if installing a new com2000 would sort this out or if a bsi update or anything would be needed, and whilst it sounds like i sort of know what these terms mean i have no idea whatsoever lmao!!
and lastly how to remove the rear bumper strip on its own as tried last week and nearly pulled my rear wings off Neutral lol
so yeh thanks for any help!
PostPosted: Sat May 21, 2011 2:56 am Reply with quote Up
For front fog lights you need:
BSI configuration set up adjustment.
You need to change the BM34 fusebox under the bonnet for one that is front fog light enabled / has the fuse holder.
You might find the front fog light wiring already there, look behind each front head light for a 2 pin grey connector plug tucked away not connected to anything.
You DONT need to change the com2000 unit to get front fogs working.
DanPug206
PostPosted: Sat May 21, 2011 3:04 am Reply with quote Up
Just saved me a question as I was going to ask this, just bought a GTi front bumper with fogs, my car doesn't have front fogs. I'll follow this guide!
Saphire Blue 206 (Gti Replica) SOLD
08 Seat Ibiza Sport
PostPosted: Sat May 21, 2011 3:06 am Reply with quote Up
Only works on multiplexed 206 Laughing
Whats yours then?
iainlovatt
PostPosted: Sat May 21, 2011 3:07 am Reply with quote Up
its dead easy to wire in fogs if the wires are not there!!!
(My Garage)
rudymason
PostPosted: Sat May 21, 2011 3:09 am Reply with quote Up
ow do i go around sorting the bsi adjustment and when would the lights come as far as the stalk is concerned??
PostPosted: Sat May 21, 2011 3:12 am Reply with quote Up
You need Peugeot Planet software to tweak the BSI unit.
Lee on here had Planet, only issue is he is far away from you.
As for the fogs.
First twist on the stalk switch would activate the fronts, a second twist would then activate the rear.
The stalk is just a switch, all it does is send a digital signal to the BSI unit which is the cars computer brain in overall charge of the electrical systems.
The BSI unit will then turn on the fog lights as requested.
DanPug206
PostPosted: Sat May 21, 2011 3:22 am Reply with quote Up
Probs won't work on mine then
Old 1999 1.4 lx
That's that put the picture then
I'm sure there's a guide on wiring them
I'll search closer to the time
Still being prepared for painting ATM
Cheers tho
08 Seat Ibiza Sport
PostPosted: Sat May 21, 2011 3:32 am Reply with quote Up
Old 1999 1.4 lx
Cheers tho
Keep your eye on Ebay, the genuine Peugeot front fog light kits turn up from time to time.
Front fogs are easy to wire in.
Its if you want to use the original stalk switch that it gets a bit harder.
rudymason
PostPosted: Sat May 21, 2011 3:33 am Reply with quote Up
so my fogs would come on with my sidelights?? dont want to sound stupid but just making sure lol!!
cheers
DanPug206
PostPosted: Sat May 21, 2011 3:36 am Reply with quote Up
Will do mate, could I get the wiring of a car that's being broke, the car in question is a v reg GTi
Cheers
08 Seat Ibiza Sport
PostPosted: Sat May 21, 2011 3:40 am Reply with quote Up
cheers
No
Your front fogs would only come on when you twist the foglamp switch.
You do need sidelights or dipped beam on first before you can activate the fog lights.
PostPosted: Sat May 21, 2011 3:41 am Reply with quote Up
Cheers
You could do.
You got crystal headlights?
DanPug206
PostPosted: Sat May 21, 2011 3:51 am Reply with quote Up
Not yet will do soon tho Smile
Currently have yellow old crappy ones
08 Seat Ibiza Sport
rudymason
PostPosted: Sat May 21, 2011 3:52 am Reply with quote Up
so then the stalk would be useless? as on mine it has sides first then full beam and thats it??
  Quick Reply
Username:
Message:
Quote the last message
