Latest: DanDan17
Overall: 17128
Online Now [210]:
Visitors: 209
Today: 23477
Total: 100623884
Forums › The Car › 206 Problems › Should there be any play??
glenpring
PostPosted: Sun May 22, 2011 5:23 am Up
there is a knocking noise coming from (what sounds like) the from suspension area got under the car checked the ball joints rod ends drop links and anti roll bar all fine
thought i would just bang hit and try to move things with my hands and the only thing i could get to make a noise was the drive shaft there seems to be play when moving it up and down
PostPosted: Sun May 22, 2011 5:47 am Up
there is a common problem with the 307 suspension,it can be fixed easily,I will get the link where I read that,and how to fix Smile
glenpring
PostPosted: Sun May 22, 2011 9:28 am Up
Ok cool thanks
PostPosted: Mon May 23, 2011 1:38 am Up
This is the Link I told you about,this will fix the knocking noise from the front :D,good luck.
www.peugeotlogic.com/w...rkshop.htm
When you click on the link,and see the homepage click on the following:
Mechanical--->you will find it on the top of the page.
on the left,you will find " Suspension Noises".
Under that topic,you will find "307 suspension creak"
The Solve in that page Smile
