Posted: Mon May 23, 2011 8:17 pm |
And what is it
Its this maroon plug above the torx screw
Posted: Mon May 23, 2011 9:07 pm |
because its not plugged in by the looks of it?
Posted: Tue May 24, 2011 12:17 am |
Check the other side
But seems like it may be ir indicator
| Abs
Peugeot 206 1.6 Sport (55)
Audi A1 2.0 TDi Sport (14) | |
Posted: Tue May 24, 2011 12:18 am |
abs06 wrote: |
But seems like it may be ir indicator |
Plug is the wrong colour & you can see the indicator is plugged in, look at the picture
Posted: Tue May 24, 2011 12:43 am |
all the lights.. indicators.. temperature readings are fine.
im just wondering what is that maroon plug meant for. it is quite wedged and i cant move it about. wanted to take the wire and see how far it could stretch to give me an idea where it came from.
but nah..
Posted: Tue May 24, 2011 12:59 am |
thats a good question, cuz when i took my car apart there were 2 plugs not plugged into owt, so i would also like to know
| Clarion VZ409E 7 inch DVD motorised screen
Sony XMZ-R604 440 watts Channel Amplifier
Vibe Slick 12" 1200 watt Subwoofer
Pioneer TS-A6903i 6 x 9 3-way 350 watts
Raceland 4-2-1 Stainless Steel Manifold
Remapped Ecu
Wolfrace Street Hustle 17"
Click For Da WIP! 206info.co.uk/Garage/m...d=336.html | |
Could it be for frosted headlights? What year is yours?
| You never really learn to swear until you learn to drive | |
Posted: Tue May 24, 2011 1:01 am |
that plug is for the alarm switch on the bonnet catch mate
Posted: Tue May 24, 2011 1:23 am |
Posted: Tue May 24, 2011 1:38 am |
Andy180+ wrote: |
that plug is for the alarm switch on the bonnet catch mate |
so where should it go?
what exactly is this alarm?
Posted: Tue May 24, 2011 1:39 am |
ive got 1 on my car but its dangling down near the floor.
| if it dont scuff the ruff it aint low enuf | |
Posted: Tue May 24, 2011 1:42 am |
bisphenol-a wrote: |
Andy180+ wrote: |
what exactly is this alarm? |
there's a plug behind the grille near the bonnet catch
Posted: Tue May 24, 2011 2:29 am |
Don't think it is.
Have it as well and bonnet switch works lovely.
Try opening the bonnet and seeing if you get message on the MFD.
Posted: Tue May 24, 2011 2:31 am |
That plug doesnt stop the bonnet opening, it just powers the bonnet alarm sensor.
Andy180+ wrote: |
Not all 206's have an alarm system fitted BUT because Peugeot use generic looms to keep costs down you may have extra plugs fitted that are not actually used due to your spec of car
If you have a factory fitted anti theft alarm system then it will connect to the bonnet sensor on the bonnet catch, being an Australian spec car I doubt it will have one as the spec is pretty mean down under.
