Posted: Tue May 24, 2011 5:01 am |
Hi,
Does anyone recommend a specific make of drop links for the 180 GTI?
Cheers.
Kev.
| - Sinature removed due to size.
Please feel free to upload one of the correct dimensions. | |
Posted: Tue May 24, 2011 5:06 am |
nellyhaggis wrote: |
Hi,
Cheers.
Kev. |
Yes, the genuine Peugeot ones you can buy at any Peugeot / Citroen main dealer
Posted: Tue May 24, 2011 5:07 am |
Check out eurocarparts.com enter your reg and you get results
Posted: Tue May 24, 2011 5:17 am |
Euro Car Parts drop links are fine, I can't remember the brand but they do seem to corrode a bit quicker than genuine Peugeot links.
Posted: Tue May 24, 2011 5:25 am |
I went for delphi and they have lasted much longer than the Pug ones, depends if your car is lowered or not?
Posted: Tue May 24, 2011 11:48 am |
pretty sure delphi is one of the oem supplier ?
