Latest: ArtistKS
Overall: 17145
Online Now [400]:
Visitors: 399
Today: 35495
Total: 116128638
Forums › The Car › 206 Problems › air con / climate pipes.....
spud_gti
PostPosted: Thu May 26, 2011 12:26 am Up
Hi all, had the front end off the pug last night and found the broken pipe have on the air con, from the pump its the lower pipe that goes onto a rubber pipe and joins up to the air con rad..... there is some form of connection there that i cant see how to release, does this pipe come seperatly from peugeot or does it come pre attached to the rad... i.e all in one??
anyone got any blown up diagrams for the aircon system that i can look at or get a part number off??
many thanks spud.
2004 GTI 180 - SOLD, 2000 GTI - SOLD, 2002 SW D TURBO - CURRENT
spud_gti
PostPosted: Thu May 26, 2011 12:42 am Up
just had a flick on ebay and the bit want to undo is a 14.5mm (i.d) female springlock?????
anyone got any ideas before the hammer comes out??
nakednakeddave
PostPosted: Thu May 26, 2011 4:52 am Up
you wont be able to replace a pipe in the aircon ans still have it work tbh....
will ne to go to a specialist if you still want aircon, and you can be fined for knowingly letting the aircon gas into the atmosphere, and its alot, so IMO best left alone....
fat exhaust, dodgy rusty bonnet, stickers and steels....
KRU KREW
spud_gti
PostPosted: Thu May 26, 2011 5:11 am Up
the pipe has already been broken so there is no gas in the system, its had a bit of a frontal bump as the rad housing is cracked in places and the air con rad looks to of had a hit, i need to get the cracked pipe replaced and then get the system pressure tested / re gassed so i can use it....
just need to know what pipe i need if anyone has a blown up diagram of the system.....
thanks for your input though
nakednakeddave
PostPosted: Thu May 26, 2011 5:13 am Up
just take it to somewhere to do it and get them to get the pipe.... ittl cost peanuts for them probobly...
KRU KREW
spud_gti
PostPosted: Thu May 26, 2011 5:17 am Up
probably right, will get the car road leagle then and take it from there....
