Posted: Fri May 27, 2011 2:50 am |
bisphenol-a wrote: |
what about those 206's in australia ?
right hand drive too.. |
The brake transfer linkage will be the same as a UK spec right hand drive 206.
Posted: Fri May 27, 2011 4:09 am |
isent it were there all built left hand drive then converted..... to check just sit in the passenge seat stick your foot around till you find a bar tap it with your foot and watch the drivers pedals move
| your defeat now is your victory in the future | |
Posted: Fri May 27, 2011 4:25 am |
i just went out to my car and literally tapped everything my foot could find, nothing happened, although mines 2005... probably just me can't find it lol, admiteddly it moved a tiny bit when i tapped one bit but not as much as in one of the videos ive seen!
Posted: Fri May 27, 2011 4:27 am |
dalton-gti-180 wrote: |
isent it were there all built left hand drive then converted |
The 206 was originally designed as left hand drive.
A lot of cars use brake transfer linkages, older Fiesta's as an example but there linkage is inside the engine comparment.
Posted: Fri May 27, 2011 5:47 am |
Tried it in my 2003 206, tapped n pushed around in the passenger footwell for 5 minutes, no dramas at all.
| An Ex '03 1.4 GLX driver, German technology all the way now. | |
Posted: Fri May 27, 2011 6:28 am |
if you poke your head under the passenger footwell and look upwards towards the centre console, you can see (on pre 2005 206's) a grey/metal column running along the front of the passenger compartment toward the drivers side - this is the brak trasnfer linkage.
It has the break light switch attached to it (so when you brake, the switch is opened and your brake lights come on)
