Latest: Worthy967
Overall: 17143
Online Now [554]:
Visitors: 553
Today: 122768
Total: 114698905
Forums › The Car › 206 Problems › Knocking noise on front suspension
PostPosted: Fri May 27, 2011 7:04 am Up
Oh god its not a 206 with this problem again....
My little 1.4 LX has had a knock from the front right side since they day it was bought. Lately it has just been getting worse and worse so thought its about time to do something about it. Had a look and the bushes on the drop links had a few splits in them. So last night changed it and it has gone a lot quieter, its not every slight change in angle on the roads there's a horrible clunk. I even managed to come along my street last night without waking everybody up Very Happy
But I do still have a slight knock there, I think the next thing is the top mount needs changing. Is this a hard job to do?
Also Would this explain the knock that I have when on full lock or would that be something else again?
JE_180
PostPosted: Fri May 27, 2011 7:10 am Up
I was going to suggest changing the top mount... but if you're planning on doing it anyway I'll shutup Very Happy
eddrj
PostPosted: Fri May 27, 2011 8:32 am Up
It will be top mount i had mine done few months ago , same noise
Old car 2000/ 206 2.0 hdi.
PostPosted: Fri May 27, 2011 9:14 am Up
How big a job is it to change?
Rob2859
PostPosted: Fri May 27, 2011 10:13 am Up
Could be the bushes on the wishbones. While we are no the subject how much extra time does it take to do when the springs are out? I might do mine when I get it lowered.
eddrj
PostPosted: Sat May 28, 2011 9:47 am Up
well cost me bout £150 at a garage if it is same ,
probably get it done for cheaper though
PostPosted: Sat May 28, 2011 9:57 am Up
if it's top mount bearing then you will hearing the nise whenever you turn the steering wheel.
