Latest: DanDan17
Overall: 17128
Online Now [194]:
Visitors: 193
Today: 26583
Total: 100587256
Forums › The Car › 206 Problems › Why it only shifts smoothly to gear 1 when stopped?
Go to page 1, 2, 3  Next
karimali831
PostPosted: Fri May 27, 2011 11:25 am Up
When I'm driving around 5mph and slowing down, I am pushing the gear stick to gear 1 but it won't shift in until I eventually stop or around 1mph? It's annoying that I have to stop to get it in gear. Sad
206 GTI 180
PostPosted: Fri May 27, 2011 11:40 am Up
normal
Rob2859
PostPosted: Fri May 27, 2011 11:41 am Up
Is it not to stop you putting it in the wrong gear when moving and throwing a rod?
Andrew
PostPosted: Fri May 27, 2011 11:50 am Up
Its normal, but it is quite annoying in slow traffic when 5-10mph is too slow to stay in second but too fast to get it into first
My 206 thread
www.detailedbyandrew.com
PostPosted: Fri May 27, 2011 12:00 pm Up
Agree when your in a derv its worse lol
cosmicdance
PostPosted: Sat May 28, 2011 2:23 am Up
Try dipping the clutch and revving a bit just before engaging first as first gear is hard to engage unless you're at very low speeds.
Andy
Andy
PostPosted: Sat May 28, 2011 2:39 am Up
I don't Seem to have this problem as I only use 1st gear when completely stopped, Razz
Way I got taught and always been told,
PostPosted: Sat May 28, 2011 2:50 am Up
Learn to drive CORRECTLY Rolling Eyes
You shouldnt be trying to select 1st gear while the car is moving, your gonna end up breaking something if you keep trying to force it in to gear.
100% operator error Wink
-Dave-
PostPosted: Sat May 28, 2011 2:54 am Up
Trade Rating: +36
I have to agree, First gear should only be selected when stopped. 2nd gear should be more than enough to drive off when the car is still moving.
Ex 206 Owner.
willb101
PostPosted: Sat May 28, 2011 3:27 am Up
Andy
this always works for me tbf. Ever have trouble getting into any gear and this usually gets it in Smile
Black 206 1.4 8v - 2007
Kill Count
Pigeon - 3
Owl - 1
Rabbit - 6+
Badger - 1 (very nearly 2!!!)
PostPosted: Sat May 28, 2011 6:01 am Up
+1
-1
-Dave-
PostPosted: Sat May 28, 2011 6:06 am Up
Trade Rating: +36
+1
-1
Explain yourself then.
Ex 206 Owner.
PostPosted: Sat May 28, 2011 6:09 am Up
www.206info.co.uk/Foru...17875.html
-Dave-
PostPosted: Sat May 28, 2011 6:19 am Up
Trade Rating: +36
I would never select first while moving and if you are going that slow you can't pull off in Second you may as well stop and select first. If your having problem's pulling off in second gear anything over 3mph I would suggest something is wrong somewhere or something has worn.
Ex 206 Owner.
PostPosted: Sat May 28, 2011 6:22 am Up
Agreed.
But some situations are a pain at least for me on a 1.4i.
Page 1 of 3
