Latest: Worthy967
Overall: 17143
Online Now [502]:
Visitors: 501
Today: 108624
Total: 115441744
Forums › The Car › 206 Problems › Battery not holding charge
Jayde
PostPosted: Sat May 28, 2011 9:57 am Up
Ok, so when I collected the car at the end of February, the guy had a new battery put in for me to be able to bring it back.
In the last couple of weeks I've had to charge it 5 or 6 times now that I only drive it to work once a week.
It's a pain in the a$s, and want it sorted to stop the hassle.
The info on the battery is
Classic
12V
40ah
60SAE
Man the F--- up!
eddrj
PostPosted: Sat May 28, 2011 9:58 am Up
alternator mabey ? not charging well enough, or just a sh*t battery
Old car 2000/ 206 2.0 hdi.
PostPosted: Sat May 28, 2011 10:00 am Up
got a mulitmeter?
check the voltage when engine off. check again when the engine is on.
voltage should be 12.5v or higher/ 13.5v or higher.
PostPosted: Sat May 28, 2011 10:01 am Up
Are you sure he put a brand-new one in?
Otherwise What He Said
antk88
if the voltage does not increase when u start the car this indicates the alternator is crap
Jayde
PostPosted: Sat May 28, 2011 10:17 am Up
Yeh he gave me the receipt, dated the day before i collected, from the garage he bought it from.
Should be able to get my hands on a multimeter over the weekend, so will check the readings.
If it's the alternator, am I looking at a b!tch of job?
Man the F--- up!
PostPosted: Sat May 28, 2011 10:21 am Up
Alternator is a bit of a pain IMO.
What year is your 206?
Is there an amp for the stereo fitted which could be draining it?
And how far away is 'work'?
Jayde
PostPosted: Sat May 28, 2011 10:30 am Up
03/180
No, haven't put anything into yet, and the head unit is taken off when the car isn't in use.
Is there anyway to check the alternator just to be sure, before replacing I may not necessarily need to?
Man the F--- up!
PostPosted: Sat May 28, 2011 10:32 am Up
Seabook wrote:
got a mulitmeter?
Wink
supercows
PostPosted: Sat May 28, 2011 10:35 am Up
i have this problem too,
but its a weird one...... had the sub, amp ect in for over 3 years and everything fine..
change the battery after the old one died and then it doesnt seem to hold its charge after ive a had the stereo on.
the query i have is that on both occasions the battery has drained i have been on a good run out in the car of 10 miles + so its not like a short run / hit on the battery not to gain a charge to power the sub , amp + stereo..
supercows
Jayde
PostPosted: Sat May 28, 2011 10:41 am Up
right, so checking the readings once I've got the multi meter and I'm sure I'll be back with more issues!!
Cheers for now guys Smile
Man the F--- up!
