Online Now [332]:
Visitors: 332
Today: 111890
Total: 155714763
Forums › The Car › Request a how-to › Removing door cards?!
karimali831
PostPosted: Sat May 28, 2011 11:05 am Reply with quote Up
SORRY if this is a silly question!
I just tried removing door cards but having problems. Embarassed
how does it remove from the top? Bottom I managed to do... I can see one pin that needs unscrewing only.
I've got 1.1 btw.
Thanks.
206 GTI 180
PostPosted: Sat May 28, 2011 11:07 am Reply with quote Up
undo 3 torx screw, remove the door handle (one screw), pull out the door opening catch and then pull out the door card
Again moved to the correction section and yet a again a search would of found the answer
www.206info.co.uk/Foru.../t=30.html
About 9 clips, three torx screws [handle, hinge side, one behind tweeter cover].
If it takes you longer than one minute, you're a retard Laughing
PostPosted: Sat May 28, 2011 11:08 am Reply with quote Up
Found another one
www.206info.co.uk/Foru...=3555.html
karimali831
PostPosted: Sat May 28, 2011 11:10 am Reply with quote Up
Ahh thanks very muchs all Very Happy
206 GTI 180
  Quick Reply
Username:
Message:
Quote the last message
