Online Now [1553]:
Visitors: 1552
Today: 129120
Total: 155222110
Forums › The Car › 206 Problems › Space saver wheel help!
ukskater01
PostPosted: Sun May 29, 2011 8:03 am Up
Hi guys and girls, yet more problems!
I got a puncture because of a screw, so I fitted my crappy space saver, I thought Id check the pressure of it with my little compressor. It said it was only 15 psi so I pumped it up to the recommended 60 psi. As I pulled the pump off the inside of the valve came with it and all the air rushed out.
I'm thinking that I'm now stuffed, can I get a valve from somewhere and are they easy to replace? The space saver didn't look very good anyway!
Thanks for your time
Andrew
PostPosted: Sun May 29, 2011 8:06 am Up
you will need to remove the tyre to fit the valve anyway....
any tyre place could do that for around 7-10 pound per corner
PostPosted: Sun May 29, 2011 8:26 am Up
Lose the space saver and fit a steelie!
PostPosted: Sun May 29, 2011 8:36 am Up
if you got the right too for that pin,you can re install it,I have one,and I used it to get other ppl tires flat if they park thier cars in my drive way (some ppl don't have maners),so I enjoy doing that,and see them do the replacment,sometimes I offer help as I'm passing,if the driver a pretty gal ;)..LOL
ukskater01
PostPosted: Sun May 29, 2011 9:46 am Up
Lol, I've had to get a taxi to the only place open, Kwickfit, cost me fifty quid but gave me a discount, think they felt sorry for me! Will a steelie fit under the car in the rack?
PostPosted: Sun May 29, 2011 9:51 am Up
It will if you move the front of the spare cage down to the lower set of fixing holes Wink
curly
simple, walk to nearest fitting garage, n give them a quid for the nipple out the valve, or like abovce get one of the screw pin drivers,, couple of quid form halfrauds,, n recycle some one elses pin Smile
and as above, through the space saver away,, there usless, they dont last long,, and are in my eyes seriously unsafe,,
for instance, would u drive a nice big porsche carrara 4s thats got 18 inch ceramic brakes, 22 inch high alloy wheels 330mm wide,,, to be replaced with a bit of tyre 30mm,,, :0
curly wurly
ukskater01
PostPosted: Sun May 29, 2011 2:07 pm Up
Your right curly, I'm gonna get a steelie and chuck the old space saver as its completely fudged! If anyone's got one let me know, I'm gonna go to a breakers soon though
Thanks for all the help!
meady
PostPosted: Sun May 29, 2011 3:12 pm Up
Trade Rating: +45
i have a steel wheel (well actually its a 106 rallye wheel but still looks like a steely) how far is sutton from basingstoke Smile
TEAM - I HATE FACEBOOK Smile
ukskater01
PostPosted: Sun May 29, 2011 4:05 pm Up
Meady it's about an hour away, might pm you if I can't get one closer
Thanks mate
curly
PostPosted: Sun May 29, 2011 5:33 pm Up
ok well just so u dont go kicking yourself, ied go and source a steel wheel carrior of a pug 106,, phase 1,, as they im allmost certain had normal steel wheel carriors underneigth,, or u may have a problem trying to mount it underneigth lol,,
curly wurly
ukskater01
PostPosted: Sun May 29, 2011 5:35 pm Up
Cheers mate, I'll have a look at the breakers
PostPosted: Mon May 30, 2011 4:04 am Up
The standard 206 wheel carrier will happily take a full size steel wheel if you move it down to the lower mounting holes on the chassis, thats why Peugeot put the extra holes in there for.
ukskater01
PostPosted: Mon May 30, 2011 10:09 am Up
Thanks mr bsi, gotta get a steelie from a breakers now Sad although I cant seeing them charge me much for one!
ukskater01
PostPosted: Mon May 30, 2011 12:17 pm Up
Sorry to be an annoyance but will I need to get the steel bolts aswell?
