Online Now [384]:
Visitors: 383
Today: 48892
Total: 156156153
Forums › The Car › 206 Problems › Space saver wheel help!
Go to page Previous  1, 2
PostPosted: Mon May 30, 2011 1:29 pm Up
ukskater01 wrote:
Sorry to be an annoyance but will I need to get the steel bolts aswell?
Yes
gazza82
PostPosted: Tue May 31, 2011 7:40 am Up
Do you? The alloy bolts with the washers have a shoulder just like a steel wheel bolt and in the handbook it clearly shows how these fit the steel wheels. I wouldn't use them if the steel wheels were a permanent fixture, but for a temporary fit I think you'll be fine.
PostPosted: Tue May 31, 2011 10:27 am Up
Normal steel wheels use a TAPER bolt, taper alloy wheel bolts on a Peugeot / Citroen aint fitted to every model so its advisable to get the correct steel wheel bolts as well as the wheel.
Page 2 of 2
