Forums › The Car › 206 Problems › radiator? |
Posted: Wed Jun 01, 2011 4:41 pm |
hi, does any 206 radiator fit a 206 gti?? or is a 140 same as a 180?? ehich ones could i use on a 180? cheers
Posted: Wed Jun 01, 2011 4:58 pm |
they are different at the bottom hose
Posted: Wed Jun 01, 2011 5:03 pm |
what about the 140??
Posted: Thu Jun 02, 2011 1:50 am |
I'm sure the differences are just age related though. Late model 138's will have the same radiator as 180's.
