Latest: DanDan17
Overall: 17128
Online Now [74]:
Visitors: 73
Today: 13554
Total: 100574259
Forums › The Car › 206 Talk › Is this any good?
Is this any good?
acotton21
PostPosted: Fri Jun 03, 2011 2:56 am Up
just flicking through egay and came across This and thought it was quite good, so thought someone on here would give me some advice whether to get it or not?
Ant
Golfguy206
PostPosted: Fri Jun 03, 2011 2:57 am Up
aparrently its not a good idea to use NGK plugs in a 206.
Can some one else confirm please??
Original Info member since June 2006.
2002 (plexed) China Blue 206 1.6 XSi - but it needs Coilovers!!
Big_Rich180
PostPosted: Fri Jun 03, 2011 2:58 am Up
Looks ok, dont know what the brand is though, I also thought the fuel filter was in the fuel tank on a 206 so it shouldnt need doing, but someone would need to back this up as im not sure.
EDIT: NGK plugs are a no, as above.
Twidly
PostPosted: Fri Jun 03, 2011 3:03 am Up
Why are NGK plugs a no? I think that's what my mum's has got in it after we put some cheaper ones in & they failed within 6 months...
Big_Rich180
Something to do with it knackering the coil pack IIRC.
Its fairly common knowledge on here so have a search it will give you more answers than i can.
craigdmjv
PostPosted: Fri Jun 03, 2011 3:05 am Up
what ones do you need then as i need some
Big_Rich180
PostPosted: Fri Jun 03, 2011 3:06 am Up
People on here recommend Bosch Super 4's
jimjam19927
PostPosted: Fri Jun 03, 2011 3:13 am Up
Yer Bosch super 4s are the best way to go. The whole NGk thing has been covered many a times. Stay clear
Member: 685
I Over Use Smilies Razz
craigdmjv
PostPosted: Fri Jun 03, 2011 3:25 am Up
how many do i need for a 206cc 1.6 16alve nfu engine
PostPosted: Fri Jun 03, 2011 3:31 am Up
NGK have a somewhat modified anti-interference resistor and can cause
problems with the ECU. That's defo.
Loads of people fit Super4 but the only one specified by Bosch is Super+ FR7DC+ which is Ytrium, single electrode.
That is for 1.4i at least. The original FR8DE has been discontinued ages ago.
Then there's Eyquem brand which are OEM for pug.
Big_Rich180
PostPosted: Fri Jun 03, 2011 3:55 am Up
You taking the p**s?
Kersh
PostPosted: Fri Jun 03, 2011 4:00 am Up
loooool
Member number: 36
