Latest: DanDan17
Overall: 17128
Online Now [53]:
Visitors: 52
Today: 15098
Total: 100442809
Forums › The Car › 206 Problems › clock display not working? Where to buy bulbs?
Go to page Previous  1, 2
Junglist206
PostPosted: Sat Jun 04, 2011 10:58 am Up
Lee wrote:
Non-plexed
Rare and expensive s**t!
Don't say that lol. How much rougly? Can I not fit non-plexed one in there?
PostPosted: Sat Jun 04, 2011 11:06 am Up
You need a non-plexed one.
PPT30 connecter = nonplexed
Think they sell for about £50
Junglist206
PostPosted: Sat Jun 04, 2011 11:12 am Up
Cheers Lee nice one. Is this the one I need
cgi.ebay.co.uk/Peugeot...2564467722
PostPosted: Sat Jun 04, 2011 11:14 am Up
Si
Junglist206
PostPosted: Sat Jun 04, 2011 11:21 am Up
Lee wrote:
Si
? Not sure what that means. Any clock display with the code PPT30 will work on my GTi T reg. Cheers Smile
PostPosted: Sat Jun 04, 2011 11:24 am Up
Yes - that is the right clock
No - any that say ppt-30 won't be the right one. PPT-30 is just the connector. It needs to be a multiline display with a PPT30 connector, as you can get single line displays with ppt30 sonnectors.
Junglist206
PostPosted: Sat Jun 04, 2011 11:27 am Up
I understand now cheers Lee. I can be bit thick at times lol. Don't take much to get me confused. Once again cheers man.
PostPosted: Sat Jun 04, 2011 11:38 am Up
It might be worth having a go at dis-assembling it carefuly and tightening-up
the screws which fix the glass panel onto where it joins with the rubber bridge to the main board.
'Have fixed many LCD's like this in the past but it's a fiddly job as you have to
line-up the LCD perfectly with the bridge connector and it also depends on the exact
mechanical design of the part. If you can see screws on the back, try simply doing them up
tightly without snaping anything obviously.
Worth a go before binning it though..
Junglist206
PostPosted: Sat Jun 04, 2011 11:43 am Up
Nice one I go do that now for some thing to do. Worth try not like I can damage it. Cheers bud
I let ya know if I have any luck.
Junglist206
PostPosted: Sun Jun 05, 2011 2:55 am Up
I took it part this morning pluged it back in without the case on, and only 1 light bulb lights up. Does anyone know where the best place I can buy the bulbs from? Could I get them in Halfords? Cheers guys Smile
PostPosted: Sun Jun 05, 2011 5:02 am Up
In your case it is not a backlight issue by the looks of your pic. in page 1.
You need to get the text appearing properly first, then sort-out the bulbs for the backlighting..
Page 2 of 2
