Posted: Thu Jun 02, 2011 6:06 am |
Hi all,
to cut a long story short I recently changed head gasket as I had the common oil leak. All was well for a week doing short journeys to work etc.. Went on a long run and after about an hour I could smell fuel, turned out an injector was leaking. I thought this was probably because I used universal o rings on the injector seals. Bought new ones from Peugeot (£30) fit them and set of back home. About 40 mins in the car cut out and now wont start.
I thought it was the injector seals again because when I put my hand round the back and put a little pressure on the injectors they leaked again. But would this stop the car from starting?
I changed the seals again taking care to fit them properly (with a little oil to ease them in) but it still wont start. Any Ideas? I have fuel in the rail but dont know if it is getting to the engine.
Its a 2001 206 1.4 manual by the way. Any help would be greatly appreciated.
Cheers,
Jase
Posted: Thu Jun 02, 2011 6:08 am |
forgot to say, it tries to fire up but keeps on turning over.
If they are leaking they're either broken or you really can't have put them back in properly. They aren't the easiest things to stuff back into place remember.
Posted: Thu Jun 02, 2011 6:14 am |
I may be reading it wrong but do they still leak? If not the engine may be flooded?
| Renault Twingo 1.2 GT TCE, AP Coilovers, 25mm Hubcentric Wheel Spacers (Rear), 16" Speedline Turini Alloy Wheels, Renault Sport Cup Spoiler,, BMC F1 Panel Filter, Forge Dump Valve, Front Mounted Intercooler, K-Tec SS Cat-Back Exhaust System, K-Tec Decat Pipe, K-Tec Remap. 136.6 BHP 154.3 lbs/ft. | |
Posted: Thu Jun 02, 2011 6:38 am |
Might sound silly but get a mate to tow it while you try bump starting it worked for me once.
| Image removed due to size
focus st 3 with pro alloy intercooler, 3" mongoose down pipe, 200 cell sports cat and mongoose cat back, collins bov, dreamscience dsci cold air intake,focus rs injectors,focus rs oil cooler,dreamscience dsci tuneing platform mod X map,focus rs clutch & flywheel, rs fuel pump, polly bushes in wish bones rear axal and suspension white line front and rear arb, eibach pro street s suspension. | |
Posted: Thu Jun 02, 2011 8:36 am |
NICKST wrote: |
Might sound silly but get a mate to tow it while you try bump starting it worked for me once. |
Don't, as you can cause damage.
Posted: Thu Jun 02, 2011 8:52 am |
try the multiplug that goes into the injector rail. when i did the headgasket i never plugged it in properly (because its a pain in the ass to reach) and it just kept turning over and not firing....
but works fine now
Posted: Sun Jun 05, 2011 2:44 am |
pres big red button, and check all connections / fitment off injectors
| *DEAD*206 Gti 138
Toyota Celica T sport 205 BHP | |
Posted: Sun Jun 05, 2011 3:01 am |
Take the plugs out and see if they are all covered in fuel. Or try adding a bit of throttle on start up to help clear the fuel out.
