Posted: Sun Jun 05, 2011 12:20 pm |
Drove to FCS last night in my 180 with some friends, enjoyed the day today... drove home and my rear engine mount decides to give up and snap on the way, which then snapped the gear linkage cable. Luckily it was only about 10 miles from my house so RAC managed to tow me home
Is this a possible 'home fix' job? Or am I going to have to get it garage repaired?
Also, where can I get some decent engine mounts that aren't soft as s**t and sheer off the car?
Rant over.
| Renault Twingo 1.2 GT TCE, AP Coilovers, 25mm Hubcentric Wheel Spacers (Rear), 16" Speedline Turini Alloy Wheels, Renault Sport Cup Spoiler,, BMC F1 Panel Filter, Forge Dump Valve, Front Mounted Intercooler, K-Tec SS Cat-Back Exhaust System, K-Tec Decat Pipe, K-Tec Remap. 136.6 BHP 154.3 lbs/ft. | |
Posted: Sun Jun 05, 2011 12:24 pm |
don't think you can fix it urself as the rear bush are pressed into the bracket.
contact macj if you want the uprate mount.
Posted: Sun Jun 05, 2011 12:26 pm |
Seabook wrote: |
contact macj if you want the uprate mount. |
Was watching his tracktime earlier What's the going rate for one?
Posted: Sun Jun 05, 2011 1:14 pm |
Or spoox motorsport iirc. Vibra-technics I think they are...
spike_202 wrote: |
My Powerflow is quite loud but then again it's on ITBs and has a decat. |
Audi Sport | |
Posted: Sun Jun 05, 2011 1:16 pm |
I can speak to Ed for you John. He's got solid mounts on his 206.
Posted: Sun Jun 05, 2011 2:02 pm |
were was you watching track time lol
| your defeat now is your victory in the future | |
Posted: Sun Jun 05, 2011 2:18 pm |
Don't uprate just one mount, they are designed to work together. Fitting original mounts with uprated mounts means the engine can move the uprated mounts more than they want to be moved.
Also don't buy from Spoox when they just sell Vibra Technics mounts with a Spoox label on them.
Anyway, what broke on the rear mount? Is it something an uprated mount would fix? I imagine it isn't.
Posted: Sun Jun 05, 2011 11:49 pm |
I was planning on uprating all of them, I just need telling which ones i should buy. Apparently ragging it home from fcs did it but we weren't even driving hard most of the time, just the odd blip at traffic lights on dual carriage ways :/. but it could have been damaged in the crash i had
Posted: Mon Jun 06, 2011 1:45 am |
dalton-gti-180 wrote: |
were was you watching track time lol |
FCS...
