Latest: Andyblue64
Overall: 17123
Online Now [494]:
Visitors: 493
Today: 76556
Total: 98163751
Forums › The Car › 206 Problems › help needed realy bad for mot
jamie1212
PostPosted: Tue Jun 07, 2011 1:34 am Up
i car has faid mot retest on emisions there realy realy high how do i get them down ? just found out its a 1.1 on logbook and a 1.4 engine fitted to 1.1 ecu and injectors can any one help
s yorks 206
Kersh
PostPosted: Tue Jun 07, 2011 1:39 am Up
youve just found out?
you say its a retest? did it pass emissions the first time round?
how far out was it?
Member number: 36
JE_180
PostPosted: Tue Jun 07, 2011 1:43 am Up
Rag the s**t out of it and get the cat nice and hot before you take it in for a retest ?
jamie1212
PostPosted: Tue Jun 07, 2011 1:53 am Up
i raged the s**t out of it temp was well up and the mot tester had to rev it uo to 5000 rmp just to get it to drop the emisions and when it droped to 2000 it went bk high
s yorks 206
PostPosted: Tue Jun 07, 2011 1:54 am Up
what was the reading and/or how far was it out? do you have the paper?
jamie1212
PostPosted: Tue Jun 07, 2011 2:05 am Up
it failed on fast idle test
fast idle test no1
2500-3000 rpm
co .30% 0.56%
hc 200ppm 171ppm
^0.97 - 103 1022
2nd test fast idle
2500-3000 rpm
co 0.30% 0.30%
hc 200ppm 272ppm
^0.97-103 1.057
s yorks 206
PostPosted: Tue Jun 07, 2011 2:43 am Up
What He Said
What fuel are you using? Shell v-power is the best to fill up with before the MOT.
Failing that get some Redex fuel treatment to give the engine a good clean.
When was the last service? May find that the air filter and dirty plugs are adding to the problem
What year is the car, might be ready for a new CAT.
Was it tested as a 1.1 or a 1.4? Your max permitted of 0.30 and 200 are the same as my 1.4. Couldn't say what a 1.1 allows.
What else did it fail on to need a retest in the first place?
PostPosted: Tue Jun 07, 2011 2:59 am Up
My old one did this to me before, ended up buying a new cat but was still out, so then got some redex which kind of sorted the problem so tried taking it for a lang drive out before mot which got it to fly through!
Not all places give the car enough time to warm up so it can be out, give redex a try first then rag it
GL
jamie1212
PostPosted: Tue Jun 07, 2011 3:24 am Up
i there i have put a full bottle of redex in been in 3 days ago it was realy hot car had worm up just thinking could it be down to the 1.4 engine running on 1.1 ecu
s yorks 206
PostPosted: Tue Jun 07, 2011 4:04 am Up
I left my car at the garage all day for the MOT, so not sure if it's still the probe up the tailpipe or if it is all measured electronically.
I suppose in theory the engine should be running leaner with a 1.1 ecu fitted, although the computer could be confused as it is needing more fuel to fill the cylinder. I don't suppose you will know if the car feels underpowered or not.
PugJH
PostPosted: Tue Jun 07, 2011 4:15 am Up
What else wasnt changed other than the ecu?
what cat does it have on it at the moment, sensors etc
WIP: Black 1.6 16v XSi
Beauté Noire
PostPosted: Tue Jun 07, 2011 5:46 am Up
looks like you got an air leak.
your o2 reading is quite high.
jamie1212
PostPosted: Tue Jun 07, 2011 6:10 am Up
the car has 1.4 engine with 1.1 ecu and injectors exhaust thats all i know and car feels under powerd ?
s yorks 206
jamie1212
PostPosted: Tue Jun 07, 2011 6:11 am Up
the car has 1.4 engine with 1.1 ecu and injectors exhaust thats all i know and car feels under powerd ? could i put 1.4 injectors would that help it on a 1.1 ecu ?
s yorks 206
