Latest: Mr-Koekwaus
Overall: 17125
Online Now [426]:
Visitors: 425
Today: 59818
Total: 99485293
Forums › The Car › 206 Talk › HELPP..
HELPP..
L5_UKS
PostPosted: Thu Jun 09, 2011 6:01 am Up
Right only picked up my new car yesterday and have the first problem today ha!
Well went to change my wheels over and managed to snap one of the bolt off in the hub. :(, The previous owner also did the same thing so now left with only 2 bolts holding the wheel on Sad
Whats the best way to get the bolts out the hub? heard you can drill them out?
Luke.
JE_180
PostPosted: Thu Jun 09, 2011 6:03 am Up
That would be alot easier to read with some punctuation in mate lol. You might have to get someone to come out and remove it, there are specialised companies that deal with stuff like that.
roberto.f
PostPosted: Thu Jun 09, 2011 6:06 am Up
Could be wrong, but it sounds like they're overtightened, so there isn't much chance of them coming out. Worse case scenario would be a new hub.
Jun 09 - Nov 09: Peugeot 106 1.1 Independence
Nov 09 - January 10: Vauxhall Astra 1.6 8v Club
January 10 - June 10: Peugeot 206 1.4 GLX
June 10 - Present: Peugeot 206 2.0 GTi
Big_Rich180
Did you buy this from a dealers, if so, take it back.
L5_UKS
PostPosted: Thu Jun 09, 2011 6:10 am Up
Sorry just wrote it out quickly, edited now Smile
And no i didnt buy it from a dealer so cant go back really, Ive heard you can drill them out? or how hard is it to change the hub?, If i can get hold of one for cheap i dont mind doing that.
JE_180
PostPosted: Thu Jun 09, 2011 6:11 am Up
If you drill them out you're going to ruin the threads on the hub, which would pretty much be pointless.
stud extractors are your best bet for DIY
Spray some WD40 over the area and leave to soak in a bit then use the stud extractors
www.machinemart.co.uk/...wrench-set
Big_Rich180
PostPosted: Thu Jun 09, 2011 6:12 am Up
I think you can drill down the middle of the bolt but I would be really carefull, you dont want to go drilling in the thread.
I'd just take it to a garage mate (if you can).
meady
PostPosted: Thu Jun 09, 2011 6:18 am Up
Trade Rating: +45
Wht car is it on
TEAM - I HATE FACEBOOK Smile
JE_180
PostPosted: Thu Jun 09, 2011 6:22 am Up
2003 Gti 180 isnt it?
Golfguy206
WD40 and stud extractor FTW!! a bit of DIY.
Original Info member since June 2006.
2002 (plexed) China Blue 206 1.6 XSi - but it needs Coilovers!!
Big_Rich180
PostPosted: Thu Jun 09, 2011 6:25 am Up
meady wrote:
Wht car is it on
www.206info.co.uk/Foru...32125.html
JE_180
PostPosted: Thu Jun 09, 2011 6:27 am Up
p_anit
PostPosted: Thu Jun 09, 2011 6:35 am Up
Where has the bolt snapped? I had the same issue, but I could get the wheel off. local garage welded a nut to the exposed bolt and were able to take it out. If that makes sense?
99 Green 1.6 GLX!!! No Mods but i keep it clean!!!
Davo_Pug
PostPosted: Thu Jun 09, 2011 7:31 am Up
possibly try getting a garage/fabricator to to tap thread the bolt (make a new thread)down the middle of the snapped bolt. Then insert a new smaller bolt to use to unscrew the snapped one...hope that makes sense. I have never tried this on a wheel...but have had it done to other bolts before..i dont see why it wouldnt work as I cant see how what s being held on(wheel) would make a difference to the process.
Davo_
