Posted: Thu Jun 09, 2011 11:27 am |
the wife has a 2002 206 1.4 hdi
she came home around 3 weeks ago complaining about a grinding noise
so i jacked the car up and sure enough the noise came from the gearbox
1 fresh gearbox later the noise is still there so i change the driveshaft
comfident i've cured it i take it up the road
guess what the noise is still there
so i take the driveshaft off again to replace the seal which was pouring oil
guess what the wheel bearings shafted
so the moral of this story is
if you get any strange nioses that sound like its coming from the gearbox
check the wheel bearing first
Posted: Thu Jun 09, 2011 11:39 am |
well.
look at the good side. at least you don't have to touch the driveshaft and gearbox forever now!
Posted: Thu Jun 09, 2011 11:43 am |
Oops at least you found out what it was eventually.
Posted: Thu Jun 09, 2011 11:45 am |
yes but its amazing how the sound seems to travel up to the gearbox
but look on the bright side at least i got to drive my l400 deli around
Posted: Thu Jun 09, 2011 11:47 am |
and ya can sell the gearbox off, to get some money back. soften the blow a tad
Posted: Thu Jun 09, 2011 11:57 am |
Gearbox noises tend to vary whether the car is throttle on or off or just coasting in neutral.
Posted: Thu Jun 09, 2011 12:15 pm |
na im gonna keep the gearbox as it looks like there like goldust
and as we run two of them its a no brainer
Posted: Thu Jun 09, 2011 1:56 pm |
MA box can never be gold dust.
so as the BE box.
