Online Now [403]:
Visitors: 402
Today: 125508
Total: 155081238
Forums › The Car › 206 Talk › FULL sp kit?
FULL sp kit?
Forum Index › 206 Talk
Go to page Previous  1, 2
PostPosted: Fri Jun 10, 2011 4:23 am Up
Silver button handbrake lever is standard fit on the higher spec / sporty 206's, its not an SP part.
PostPosted: Fri Jun 10, 2011 5:09 am Up
didnt know my SE was that high in the range Laughing
PostPosted: Fri Jun 10, 2011 5:13 am Up
SE is a pretty good spec for a 206 Cool
There wasnt that many optional extra boxes that could be ticked at the time of order as the SE had most kit fitted as standard
PostPosted: Fri Jun 10, 2011 5:15 am Up
ah right thats a good thing i suppose and the fact that the buyer paid for the extra bits like CC'ing, arches, spoiler etc Razz Laughing
PostPosted: Fri Jun 10, 2011 5:18 am Up
Think the available SE optional extras where:
RT3
JBL speaker upgrade
CD changer
Cat 1 alarm upgrade
Side / curtain airbags.
PostPosted: Fri Jun 10, 2011 5:20 am Up
Cheers for that. Does that mean I could most probably retrofit that stuff and any appropiate cables should already be there?
PostPosted: Fri Jun 10, 2011 5:24 am Up
Side airbag wiring should be there.
Lift up the rubber door seal & unclip the carpet, look in the middle where the wiring loom is for a black plug with 2 wires going to it not connected to anything, if you find it then the side airbag wiring is there.
Curtain airbag wiring possibly but you need to change the headlining to fit the airbags.
Side airbags are easy to retrofit on a 206, ive done it to mine a couple of years back Cool
Cd changer should be a glovebox mounted one on an SE
Its a case of seeing if there's hidding connector plugs for the equipment your thinking of adding then of course a BSI configuration tweak.
PostPosted: Fri Jun 10, 2011 5:28 am Up
Yes the slot is there in the glovebox for a mounted CD Changer but felt around at the back and couldnt feel a wire. Might have to check the back of the headunit though and see if its dropped futher down or something.
Airbags possibly depending on price but nice to know that it could be possible if the wiring is there nevertheless!
Just going to have a gander on servicebox Laughing
Cheers again Smile
PostPosted: Fri Jun 10, 2011 5:29 am Up
People love to call things SP but i had a chat with a guy at my local peugeot garage and i was told the SP kit was as follows;
-Morette headlights
-Lexus rear lights
-Wheel arches
-Bonnet vent
-Lower bumper grill
-Upper grill (either side of the badge)
-Fuel cap
-Floor mats
The other claimed SP bits;
-Handbrake
-Pedals
-Door handles
-Gear knob
-Vent sliders
These are simply parts found on the higher spec models and are NOT SP parts.
PostPosted: Fri Jun 10, 2011 5:44 am Up
wow just seen so many items I havent before. There is the wood effect centre console
Only like £165!!! lol (9622 97)
PostPosted: Fri Jun 10, 2011 5:45 am Up
You need these for retrofit side airbags on a multiplexed 206 Wink
Autoliv 600 23 70 00 is the airbag ecu you require.
Autoliv 550 90 30 00 are the sill sensors & you need 2 of those.
If the black sensor plug is there then the green airbag plug will be hidden under the carpet secured to the wiring loom, you need to remove the front seat, lift the carpet up to cut the cable tie securing the green plug & then post the plug up through the slot in the carpet so you can then connect it to the seat.
The sensors are best fitted with the front seat removed as access is very tight, repeat for the other side.
Before you ask im NOT selling those, there part of my stock of 206 parts for future use.
PostPosted: Fri Jun 10, 2011 5:47 am Up
A general question - why cant the standard airbag ECU be used??? Shouldnt that have the same capabilities??
PostPosted: Fri Jun 10, 2011 5:51 am Up
Because its not compatible with the 2 black satellite sensors needed for side / curtain airbags.
PostPosted: Fri Jun 10, 2011 5:55 am Up
Oh right ok! Strange that if the wires would be there already abit odd to not include a corresponding ECU?!
Obviously youve already done this so accept what you're saying! Cool
Page 2 of 2
