Online Now [566]:
Visitors: 565
Today: 123691
Total: 105850270
Forums › The Car › 206 Problems › linkage and leaks
linkage and leaks
ian89
PostPosted: Fri Jun 10, 2011 5:17 am Up
right the first problem i ran into was getting the catr home it was totally fine until i got to the traffic lights near my home i tryed to select first but couldnt find it then when i did it just grinded the gears so i got 2nd and struggled to pull off but got moving.
the gears i can find 2,3,4,5,R yet when im in a gear the stick does not stay in place its very loose and can put it in a gear like 2nd for instance and slide it along toward reverse
heard it could be the linkage thaught id check on here what the 206 experts say thanks.
also i have an oil leak not sure if its the engine or steering fluid of both and they are both coverd in oil. and how do i check the steering fluid level
PostPosted: Fri Jun 10, 2011 5:26 am Up
Power steering:
Open the bonnet & remove the cap that has a picture of a steering wheel on & also POWER ASSISTED STEERING printed on it.
You will find a dipstick attached to the cap.
Gearlinkages do wear, replace the link rods there cheap enough new from any Peugeot / Citroen main dealer.
meady
PostPosted: Fri Jun 10, 2011 6:34 am Up
Trade Rating: +45
What engine 206 have you got as i have a set of uprated pugsport group n gear linkages for sale
TEAM - I HATE FACEBOOK Smile
ian89
PostPosted: Fri Jun 10, 2011 8:13 am Up
all i know is that its a 1998 1.4 8v
ian89
PostPosted: Sun Jun 12, 2011 8:56 am Up
ok i thaught it was the linkage but i can select gears but have 2 force them in and sometimes not often but sometimes when i select 1st and go to move off the engine struggles like its trying to cut out.
anyone got any suggestions
ian89
PostPosted: Mon Jun 13, 2011 8:53 am Up
update* the linkage was snapped off on the bottom rod just a quick queston though thers a big ball joint should there be a rubber bush?
and the oil leak was fluid hopefully so changed the steering resivoir
