Online Now [55]:
Visitors: 54
Today: 95620
Total: 105234724
Forums › The Car › 206 Problems › Noise from blowers?
Noise from blowers?
PostPosted: Sat Jun 11, 2011 6:10 am Up
Hi all, im having a problem with my blowers and nobody i know has managed to figure out what it is.
When i turn them on, hot or cold there is a noise (like a whirring noise) coming from like where the passenger airbag is, any idea what this could be and how to get rid of it?
If i turn blowers off it stops so im stuck for where to look
Cheers for any help you lot
cartoonhead
PostPosted: Sat Jun 11, 2011 6:31 am Up
mine has had the same problem for the last 2yrs but only on stage 1 and ive just put it down to either the fan blades off balance or its the motor bearings worn Sad
MrrNoName
PostPosted: Sat Jun 11, 2011 8:48 am Up
what he said, if it really bothers you replace the blower motor, Wink
PostPosted: Sat Jun 11, 2011 8:52 am Up
I have a blower motor on eBay atm. 50 or best offer. I'll give you forum discount Smile
PostPosted: Sat Jun 11, 2011 8:55 am Up
Is that defo what it is then, a nakered blower motor?
bashyy1
PostPosted: Sat Jun 11, 2011 9:20 am Up
worth replacing to see...easy to do if u get a cheap one.
Aegean Blue Gti 180.
Project Thread
PostPosted: Sat Jun 11, 2011 9:21 am Up
Need to find out where the bloody thing is located first of all lol
MrrNoName
PostPosted: Sat Jun 11, 2011 9:24 am Up
i believe its in the dash behind the controls and can be reached by removing the glovebox.
Thats the only thing that moves the air, so it makes sense its that.
PostPosted: Sat Jun 11, 2011 9:26 am Up
Thankyou very much, i need to sort out my sub power cable through there anyway so kills 2 birds with 1 stone Very Happy
MrrNoName
PostPosted: Sat Jun 11, 2011 9:48 am Up
go on servicebox and type your vin in, then under job click electric unit on the left, then go down to comfort and convenience and click "heating /air con". When the list appears click the one starting with "air puller" and you get a diagram of the system up which shows where the motor is located.
Im about to change my blower motor resistor because my setting 1 doesnt work lol Wink
PostPosted: Sat Jun 11, 2011 9:50 am Up
Thanks for all the info, i have no idea what servicebox is but ill use good ole google for it.
Its such a horrible noice, only tends to do it when its low speeds
MrrNoName
PostPosted: Sat Jun 11, 2011 9:54 am Up
public.servicebox.peugeot.com/
its peugeots service for diagrams and part numbers etc, its good
User: AP18596253
Password: 206info
PostPosted: Sat Jun 11, 2011 10:17 am Up
Thankyou very much mate Very Happy
PostPosted: Sun Jun 12, 2011 2:50 pm Up
Do you have digital climate control?
As there are 2 types of blowers.
I had to replace mine as it was making an annoying squeaking noise on low speed.
Norvvv
PostPosted: Sun Jun 12, 2011 4:51 pm Up
Mine only works on 4 :L 1,2 and 3 don't do anything. New motor?
2001 1.4lx
PrePlexed 5 door.
