Latest: sparrowdclxvi
Overall: 17139
Online Now [517]:
Visitors: 517
Today: 52347
Total: 112736307
Forums › The Car › 206 Problems › car cuts out/stalls
car cuts out/stalls
keeno
PostPosted: Sat Jun 11, 2011 9:31 am Up
Ola ladies n gents,
Just a quick question, does anyone have an issue with there car stalling randomly whilst driving??
Happens normally when i break and change to a lower gear at the same time. Happened today n lost all steering whilst turning left at a junction Crying or Very sad
there's no indication of it stalling just cuts out and have to turn the ignition again Confused
Any ideas??? Please
206 Gti 180
abs06
PostPosted: Sat Jun 11, 2011 9:35 am Up
mine stalls when i reverse off the drive and stop, the car cuts out, but then start up and is fine. happens 2/3 times a month and early in the morning. but never while driving.
Abs
Peugeot 206 1.6 Sport (55)
Audi A1 2.0 TDi Sport (14)
dopey
PostPosted: Sat Jun 11, 2011 9:38 am Up
Mine has done that a few times in the two years Ive owned it and so has my cousins one =/ never found out what it is to be fair.
Kinda scary when the steering locks though!
keeno
PostPosted: Sat Jun 11, 2011 9:40 am Up
yup, good job nothing was coming!!
206 Gti 180
PostPosted: Sat Jun 11, 2011 9:41 am Up
No you didnt, you simply lost the power assistance Rolling Eyes
Steering wont lock unless the ignition key is removed from the barrel.
keeno
PostPosted: Sat Jun 11, 2011 9:42 am Up
felt like i had lost steering all together
206 Gti 180
MrrNoName
PostPosted: Sat Jun 11, 2011 9:50 am Up
it just goes really stiff because your having to manually drive it + the pump.
happens to me very occasionally, its annoying as hell lol
Happens to me aswell quite rarely though, but what a b*****d when it happens
keeno
PostPosted: Sat Jun 11, 2011 9:54 am Up
any ideas wat it is?
206 Gti 180
MrrNoName
PostPosted: Sat Jun 11, 2011 9:56 am Up
no idea, not something to do with the air intake though. must be the ECU or fueling
keeno
PostPosted: Sat Jun 11, 2011 9:59 am Up
Very strange!!
206 Gti 180
PostPosted: Sat Jun 11, 2011 10:16 am Up
well for it to cut out, its like there's a lack of power to the car from the battery so maybe something along those lines?
keeno
PostPosted: Sat Jun 11, 2011 12:26 pm Up
Arh ok, ill ava look
Tomoz, tho gunna b honest not got a clue wat im looking for!!
206 Gti 180
jedwards
PostPosted: Mon Jun 13, 2011 4:50 am Up
mine does this, revs drop really low when putting the clutch in then sometimes will just stall, bad for when changing for a corner! It's my ICV as i was told to clean it a while ago and it just got worse after that eventually sometimes starting and it idling at 3000rpm!
dsdasdsad
MrrNoName
PostPosted: Mon Jun 13, 2011 7:04 am Up
if its your ICV just change it, it takes less then 5 minutes and you can get one on ebay for about £18 that works fine, problem is that some of us already have changed it (from the stealers! total rip off lol) and the problems exactly the same.
