Latest: Worthy967
Overall: 17143
Online Now [498]:
Visitors: 497
Today: 106069
Total: 115137156
Forums › The Car › 206 Problems › Another problem
Another problem
bashyy1
PostPosted: Wed Jun 15, 2011 1:36 pm Up
Hii,
So i've got another problem with the 206. Just had the head gasket done on the weekend which got rid of the horendous oil leak i had.
Went out for a drive earlier and there's loads of smoke coming out of the bonnet and from the exhaust and so i park up and there's oil leaking from the joint between the gearbox and the engine, the gear have been feeling really loose then heavy randomly.
It only leaks when the engines on though. Its had 3 or 4 oil changes recently to remove water contamination.
Is the gearbox gone or what could this be?
Aegean Blue Gti 180.
Project Thread
bashyy1
PostPosted: Wed Jun 15, 2011 2:07 pm Up
Bump??
Project Thread
MrrNoName
PostPosted: Wed Jun 15, 2011 2:14 pm Up
could be that the gaskets gone. i.e the seal on the gearbox, the gears could be feeling odd because there isnt enough oil in the box any more, its common for them to *weep* from the seal, not fully leak out though
bashyy1
PostPosted: Wed Jun 15, 2011 2:28 pm Up
seal on the gearbox? If u mean the crank shalf seal thats been done already. Car just doesn't seem right, judders doesn't go into gear cant take it out of reverse without really pushing it.
Project Thread
MrrNoName
PostPosted: Wed Jun 15, 2011 2:34 pm Up
was the timing done correctly after the HG?
just looked on servicebox and it doesnt look like there is a gasket
not sure sorry Sad
