Posted: Thu Jun 16, 2011 3:12 am |
I'm needing to get this done and have been quoted around £250 all in, does this sound about right and is it just for one side or would both be done, was told would take about 2 and a half hours but got 1 wishbone done before and didn't take long at all so wasn't sure if that quote was for 1 side or both, thanks
Posted: Thu Jun 16, 2011 3:13 am |
Probs for both
| Team Impossible Possible
Posted: Thu Jun 16, 2011 5:24 am |
Doesn't sound much if they are doing both wishbones and front bearings.
Posted: Thu Jun 16, 2011 5:36 am |
i would say is one side.
or they just use rubbish parts.
Posted: Thu Jun 16, 2011 5:45 am |
I just assumed he'd be doin both bearings at least, wasn't sure though so just thought I'd ask on here for a bit of advice
Posted: Thu Jun 16, 2011 5:56 am |
Do both bearings need changing?
Posted: Thu Jun 16, 2011 6:07 am |
don't think so, I just thought things like that were done in pairs or best done in pairs anyway
he's doing 1 bearing and the 2 wishbones
Posted: Fri Jun 17, 2011 12:27 pm |
i just got my bearings done went to the scrapyard and just replaced the full hub
Posted: Fri Jun 17, 2011 12:57 pm |
Nice.
