Online Now [280]:
Visitors: 279
Today: 62974
Total: 128280588
Forums › The Car › 206 Problems › Finally got it running but. . .
Damo482
PostPosted: Fri Jun 17, 2011 2:22 am Up
So my 99' 206 1.4 8v GLX has been sitting there for over a year, and I tinker when I get bored with other things, but now I'm determind to get it running!
So I had all your usual problems coilpacks, ecu, sensors, finally got it running and idling and it will take a rev but once you rev it to say 2500 and let off the throttle it comes back down to idle struggles for a couple of seconds and then dies?
Any ideas?
Damo
iainlovatt
PostPosted: Fri Jun 17, 2011 2:26 am Up
yep mine did that when i parked it up for about a year too! Take it for a quick spin with out letting the revs drop! Smile
(My Garage)
juanfernandes
PostPosted: Fri Jun 17, 2011 2:28 am Up
Did you both just leave the car with out ever switching it on? Or does that not make a difference?
Mine is off road at the mo, sorn'd, but every other weekend I run it for a bit.
Quote::
cartoonhead
PostPosted: Fri Jun 17, 2011 2:41 am Up
petrol goe's off and smells like gloss paint.
drain the tank and get fresh petrol in if its been stood for a year
Damo482
PostPosted: Fri Jun 17, 2011 2:42 am Up
It wasn't a case of I never ran it, it was a case of it wouldn't run lol
So after a coilpack, ecu various sensors, checking my earths and for vacuum leaks, I'm so close to getting it going!
@iainlovatt taking it out for a quick spin is a problem as it's behind another car which is up on stands at the moment, and no mot tax, bla bla bla!
Damo
iainlovatt
PostPosted: Fri Jun 17, 2011 3:28 am Up
Use the bumpers then to "Bump" your way out! Smile
sounds daft but go forward and backwards in the space that you have, a few times!
(My Garage)
Damo482
PostPosted: Fri Jun 17, 2011 4:16 am Up
I've hopefully got sunday off so will give everything a go, and let ya know how I get on,
Cheers guys
Damo
ptrehearn152
PostPosted: Mon Jun 20, 2011 12:56 pm Up
What cartoonhead said, you may have to flush the whole fuel system out, old petrol can turn to jelly and clog things up.
babbum
