Latest: sparrowdclxvi
Overall: 17139
Online Now [233]:
Visitors: 232
Today: 12532
Total: 112400541
Forums › The Car › 206 Problems › Leaking Roof and Remote Key Question
Go to page Previous  1, 2
PostPosted: Fri Jun 17, 2011 8:42 am Up
PaddyC wrote:
I don't think I have the plastic card. I'll check when I get home.
The 4 digit security code is behind the silver scratch panel on the card & you need that security code if you want to code any keys to the car, any Peugeot main dealer can supply the 4 digit code with proof of id & ownership.
OR
Just ask Lee as he is a lot cheaper Wink
PaddyC
PostPosted: Fri Jun 17, 2011 8:49 am Up
Can I buy one of those key fobs from eBay and just get the chip for inside it from Lee (if I can find the code obviously!)
Then get someone locally who may be able to match it all up to the car, as they'll obviously need to be with the car when they do it!
Peugeot 206 1.4HDI Style
PostPosted: Fri Jun 17, 2011 8:57 am Up
Yes & yes.
If you dont have the blue card then ask Lee as he can get the security codes for you from the VIN number Wink
PaddyC
PostPosted: Fri Jun 17, 2011 9:00 am Up
Excellent, I shall contact Lee shortly then. Are there any types of key I should look for on eBay or are there ones I shouldn't get that wouldn't work at all?
Would this work ok? - cgi.ebay.co.uk/PEUGEOT...3cb4902068
All I would need are the circuit board and transponder chip from Lee then?
PostPosted: Fri Jun 17, 2011 9:04 am Up
Thats the correct type / shape keyfob case.
Just the circuit board & transponder chip needed.
PaddyC
PostPosted: Fri Jun 17, 2011 9:07 am Up
And Lee can definitely supply the circuit board and chip to me if I can get him the security code?
PostPosted: Fri Jun 17, 2011 9:23 am Up
IIRC to program the transponder, the car needs to be connected to Peugeot Planet. It's not just a case of buy a transponder and enter a code.
PaddyC
PostPosted: Fri Jun 17, 2011 9:44 am Up
Right, I'll have to be on the look out then for someone local who is able to do the programming and can get me a blank circuit board and transponder!
PaddyC
PostPosted: Sat Jun 18, 2011 11:20 am Up
Oh, and I also got the sealant and fixed the leaking roof problem. We had a torrential downpour all afternoon here and the car is bone dry inside!
Thanks to all for your help! Cool
PostPosted: Sun Jun 19, 2011 4:53 am Up
He can supply the transponder chip, you will have to find your own circuit board for the remote part.
Page 2 of 2
