Online Now [104]:
Visitors: 103
Today: 17498
Total: 116669357
Forums › The Car › 206 Problems › Repair bill :(
Repair bill :(
Abzynthe
PostPosted: Sat Jun 18, 2011 2:35 pm Up
East Area Rep - Abzynthe
I got a pre MOT check done today, and this is the list they gave me.
Do you know how many of these will fail the MOT? as he didnt really say. Also, the quote they gave me was £400 to fix the lot. is that ok?
O/S/R arch liner adrift
Brake load valve seized and leaking.
N/S/F arch liner catching wheel on full lock.
Leak on N/S/F CV boot.
CV joint warn on O/S/F.
Head lights are out ( I know this will fail the MOT)
I forgot to get a quote for a new inlet manifold gasket aswel, any ideas how much a garage would charge for this?
PostPosted: Sat Jun 18, 2011 2:43 pm Up
O/S/R arch liner adrift --- Cable tie
Brake load valve seized and leaking. ------ Un seize with W40 and lever bar (on rear axle)
N/S/F arch liner catching wheel on full lock. ----- Cable tie
Leak on N/S/F CV boot. ---- Replace
CV joint warn on O/S/F. ----- Replace
Tbh you could do this yourself, its not that hard
Abzynthe
PostPosted: Sat Jun 18, 2011 2:44 pm Up
Just like i did the engine myself? Razz
Im useless at mechanics Sad
PostPosted: Sat Jun 18, 2011 2:45 pm Up
Dont go there Laughing
Abzynthe
Laughing
Big_Rich180
PostPosted: Sat Jun 18, 2011 2:47 pm Up
£400 seems way over the top for what is wrong.
Abzynthe
PostPosted: Sat Jun 18, 2011 2:52 pm Up
well what they've quoted is,
£210 for the load valve
£12 for front arch liner
£155 for CV boot
£74 for CV joint
Then rounded it down to £400.
I have no idea about this stuff, so I want it as cheap as possible :S
Seb
PostPosted: Sat Jun 18, 2011 2:55 pm Up
Staff - Seb
Replace CVs, penetrating oil the load valve (are you sure it is leaking as well?).
Cable tie/seal Arch liners.
Abzynthe
PostPosted: Sat Jun 18, 2011 2:56 pm Up
yeah its says on the sheet he gave me that its seized and leaking.
PostPosted: Sat Jun 18, 2011 2:58 pm Up
one or both?
pretty sure they are not cheap, around 50 each.
Big_Rich180
£155 for CV boot
£74 for CV joint
I thought if you got a CV joint the boot came with it?
EDIT: sorry, just read your original post.
PostPosted: Sat Jun 18, 2011 3:02 pm Up
Hang on, you can replace a CV joint?
You need to replace the whole shaft?
And tbh £100 should cover it including parts
And a boot is a gator so why is it more?
Abzynthe
PostPosted: Sat Jun 18, 2011 3:18 pm Up
its probably more because they'll probably replace the cv joint aswell. not sure.
Abzynthe
PostPosted: Sat Jun 18, 2011 3:19 pm Up
one or both?
Its just says brake load valve, so im guessing one?
Lecktorious
PostPosted: Sat Jun 18, 2011 3:57 pm Up
Trade Rating: +59
Get another quote and make sure they aren't wearing a mask and a black and white stripey top as well
'98 Nile Blue 306 GTi 6
