Latest: SA01
Overall: 17138
Online Now [457]:
Visitors: 456
Today: 55847
Total: 111302226
Forums › The Car › 206 Problems › 206 gti hdi problems
peterh
PostPosted: Sat Jun 18, 2011 3:04 pm Up
Hi all,
My 2004 gti hdi 110hp has had many problems but the most recent being that the engine management light shows and the message anti pollution fault displayed, i've checked the fault codes recorder which states iat sensor, what is this and where is it located? the car seems low on power and is very jerky at low speed. Also had a problem with a front wheel bearing which caused wheel wobble under braking. I changed the bearing and discs etc which cured the problem but within 3k miles it has re appeared. would you assume the hub itself is faulty? any advice much appreciated, thanks
stevedude
PostPosted: Sat Jun 18, 2011 3:19 pm Up
might be other side now, or was it a second hand hub?
Happydays
valdice
PostPosted: Sat Jun 18, 2011 3:37 pm Up
Intake air temp sensor
Its either combined with the mass air flow sensor (maf)
Or its on its own in the pipe from the aircleaner
To tbe turbom
GARAGE OWNER
Lecktorious
PostPosted: Sat Jun 18, 2011 3:41 pm Up
Trade Rating: +59
Change the discs and pads. Should have done this before replacing the bearing, which normally makes a drone if it's knackered.
Sounds like the DPF filter may require regeneration as well. Have a search as it's been covered loads of times.
'98 Nile Blue 306 GTi 6
