Posted: Sat Jun 18, 2011 4:15 pm |
There's only one brake compensator valve? I've never seen a car with two
Posted: Sat Jun 18, 2011 5:48 pm |
Posted: Sat Jun 18, 2011 5:55 pm |
Trade Rating: +36
How far are you from Kyle, He come's Highly recommended and would be a cheaper option.
Posted: Sat Jun 18, 2011 7:06 pm |
Next time don't pay for a 'Pre MOT' check, just go to a place that does free re tests.
Posted: Sat Jun 18, 2011 7:36 pm |
Trade Rating: +36
E5GDM wrote: |
Next time don't pay for a 'Pre MOT' check, just go to a place that does free re tests. |
Which most place's now only offer if you get them to do the work. Also a lot of garage's put a time limit on a re-test which is not always suitable if its a expensive job. Pre Mot check's might be a extra expense but can save you money if you suspect something is wrong. The garage near me charge's a Tenner for a pre check which most people on here spend in McDonald's a day so not going to break the bank.
Posted: Sun Jun 19, 2011 5:03 am |
E5GDM wrote: |
Pre MOT check was free
They basically said to me to put it through the MOT so that they know exactly what needs doing, then as long as they do they work within 10 days then the retest is free. And if I book the MOT online, then its only £28. But if it works out cheaper to fix these bits before the MOT then im going to do it.
Posted: Sun Jun 19, 2011 5:08 am |
£400 is extortion.
The only real issue it the driveshaft. About £90 (after surcharge) will get you the complete shaft and then if you know someone who can do it then you are onto a winner!
Since when did they check archliners on the mot?
spike_202 wrote: |
My Powerflow is quite loud but then again it's on ITBs and has a decat. |
Audi Sport  | |
Posted: Sun Jun 19, 2011 5:15 am |
Howey wrote: |
Since when did they check archliners on the mot? |
If its hanging loose or interfering with the front wheels on steering lock then it will get picked up.
Posted: Sun Jun 19, 2011 5:18 am |
Abzynthe wrote: |
well what they've quoted is,
£210 for the load valve
I bet a Peugeot main dealer would be cheaper then that supplied & fitted
Posted: Sun Jun 19, 2011 6:24 am |
Abzynthe wrote: |
£12 for front arch liner
£155 for CV boot
£74 for CV joint
Then rounded it down to £400.
I have no idea about this stuff, so I want it as cheap as possible :S |
f***! i got my cv boot replaced for nothing!
They sound like they're trying to con you!
| Corsa B 1.2
206 2000- GLX 1.6
A mob scenes forming.... | |
