Online Now [553]:
Visitors: 552
Today: 119349
Total: 128090763
Forums › The Car › 206 Problems › Wiring in morette headlights (help)
iainlovatt
PostPosted: Mon Jun 20, 2011 1:44 am Up
Thought i would test my headlights this morning make sure they all work, wired them in, however the only light i cant get to work is the dipped beam,
I have wired in the positive wire and earthed both lights, but no joy
Any ideas? been few years since i put my last pair on!
thanks
(My Garage)
JE_180
PostPosted: Mon Jun 20, 2011 1:47 am Up
If you want I can take a picture of mine later, I had a bit of trouble wiring them back in after taking them off to tint them Saturday as I didn't take any notice of which wire went where Very Happy
iainlovatt
PostPosted: Mon Jun 20, 2011 1:48 am Up
Ye that would be of great help! Smile
(My Garage)
PostPosted: Mon Jun 20, 2011 1:51 am Up
Check the wiring of the morettes is the same as the one posted by Chris (CD) on here in the howto or faq section. Sounds like the wiring might be out.
Also sometimes the spade connection things need cleaning from any crap on it.
iainlovatt
PostPosted: Mon Jun 20, 2011 2:11 am Up
Problem solved! the earth point that i was using temporarily was rubbish! never mind! thanks for the input! Very Happy
(My Garage)
DeadEyePaul
PostPosted: Mon Jun 20, 2011 3:23 am Up
Where did you originally earth it?
iainlovatt
PostPosted: Mon Jun 20, 2011 4:02 am Up
Metal frame, were the light bolts into! obviously it wasn't good enough! Very Happy
(My Garage)
JE_180
PostPosted: Mon Jun 20, 2011 4:03 am Up
Should be on a small bolt directly behind the light as far as I remember, is that where you placed it afterwards?
DeadEyePaul
PostPosted: Mon Jun 20, 2011 4:06 am Up
This is where I put them, reason for asking is just to know if that's the good place to put 'um
JE_180
PostPosted: Mon Jun 20, 2011 4:13 am Up
Seems fine on mine lol, haven't had any problems with it!
