Online Now [609]:
Visitors: 608
Today: 106029
Total: 155063490
Forums › The Car › 206 Talk › Adding Air Con/Climate?
Forum Index › 206 Talk
Martind
PostPosted: Tue Jun 21, 2011 5:20 am Up
Hi guys,
I have a 1.4 8v on a '53'. Sadly it is quite basic model and doesn't have any air-con.
I was wondering wether it would be cheaper to get all the bits from an air-con model and fit them to mine or just trade it in/swap it for one with it from factory?
Has anyone done it on here? If anyone has, how difficult is it?
Help always appreciated Smile
Cheers
PostPosted: Tue Jun 21, 2011 5:22 am Up
Ask yourself...
Is it worth the hassle of retrofitting.. (Will be very very hard.)
Do you really want to trade in your car.
If yes to one of the above:
How often are you going to use it a year...
PostPosted: Tue Jun 21, 2011 5:27 am Up
I fitted climate control, dash out job
Air con i removed rather than fitted as i personally hate it and it adds drag to the engine
But im sure 02 onwards air con was standard?
Martind
PostPosted: Tue Jun 21, 2011 5:29 am Up
I think it would be worth the hasstle of fitting it as I find air conditioned cars help my astma. I know it will be difficult, but I don't know exaclty how hard it is.
I know I would use it regularly, as the car itself never seems to get cool and anything above 40ish MPH you have to have the windows closed.
I wouldn't mind swapping it for a slightly older 2.0HDi (to banlance out the value difference. Newer vs desireability of derv) but I wouldn't want to part with cash to get something the 'same' if you see what I mean. But I like my orange interior, but then again, I think I would like a different one just as much.
How long was it sat in a field though? Wink
PostPosted: Tue Jun 21, 2011 5:31 am Up
As for fitting it yourself. I am not sure. I know Northantsben has just removed his and it was an engine out job. You will also need to change your Aux-belt to the bigger on. IF possible.
Might be cheaper and less hassle selling yours and buying a HDi.
Martind
PostPosted: Tue Jun 21, 2011 5:35 am Up
Yep it sounds easyer to just swap or px this 206 for one with aircon/cc
But cheers for your info and help guys
PostPosted: Tue Jun 21, 2011 5:36 am Up
I have asthma it made me feel like s**t when ever i turned it on, but everyones different
You have to change the pulley set up/tensioner and a new belt. Need rad housing, radiators and you may not even have the wiring so is it really worth it? No imo
PostPosted: Tue Jun 21, 2011 6:03 am Up
Nope, it wasnt.
