Latest: Flyin180
Overall: 17116
Online Now [32]:
Visitors: 31
Today: 10427
Total: 95028534
Forums › The Car › 206 Problems › f~'&$^%g suspension knocking
robertmarcs
PostPosted: Thu Jun 23, 2011 7:18 am Up
right guys heres the scope. ive basically changed everything on the front of my car suspension wise, new top mounts, shocks, springs, droplinks, arb bushes, wichbones with balljoints and there's still a knocking coming from the front. soundslike its from the os front like a hollow knocking noise. 3 garages have checked it and they cant find anything loose and all the nuts n bolts are tight and a ducks a**e!
has anyone had this probem and solved it because it doing my head in and if it keeps it up the cars going to have a date with a gallon of petrol n a box of swan!
btw its a 2000 w reg gti.
much thanks for any help and please dont clutter this thread with spam!
Cool
Kersh
PostPosted: Thu Jun 23, 2011 7:27 am Up
engine/gearbox mounts?
Member number: 36
robertmarcs
PostPosted: Thu Jun 23, 2011 7:36 am Up
thats what i thought but theyve checked them n said theyre fine. although i may change them anyways.
Driveshafts?
Lewis
PostPosted: Thu Jun 23, 2011 7:45 am Up
is it the top mounts ? think i have this aswell! like a loose knock when you go over bumps ???
My old 1.1 had it aswell, sold it on they got it fixed and im sure they said it was the top mounts. If its the same thing as mine (a hollow rattle/knock) then it could be that
Tivoli LX 1.1
Black GTI 180
White VXR Burg
robertmarcs
PostPosted: Thu Jun 23, 2011 7:58 am Up
like i said mate everythings brand new genuine peugeot parts except the shocks n springs which are spax
Cool
move_2001
PostPosted: Thu Jun 23, 2011 8:41 am Up
I had this it could be gear box on way out or thrust bearing
only travel as fast as you angel can fly
twed207
PostPosted: Thu Jun 23, 2011 9:11 am Up
rollbar mounts?
jack the car up so the wheel's a good few inches off the ground and stick a large pry bar under the tyre and keep lifting it up and down and see if you can see where the play is. if it's lowered on springs there will already be a bit of play before it gets harder to lift the wheel
206 2.0HDi
My 207 WIP
Turbo Diesel Owners Club UK
L200 thread
robertmarcs
PostPosted: Sat Jun 25, 2011 4:16 am Up
found the os droplink top nut had come loose that was making a hell of a noise so changed the nuts on both to be sure. then found that the track rod end is knackered so changing both of them. got all the engine mountings aswell so guna change them and hopefully that will be it dun n dusted!
