Latest: sparrowdclxvi
Overall: 17139
Online Now [562]:
Visitors: 561
Today: 112507
Total: 112924008
Forums › The Car › 206 Problems › speedo problem
speedo problem
jaybooooi
PostPosted: Thu Jun 23, 2011 4:36 pm Up
hi everyone need a big help, my revometer needle moves backwards when the mileage countr goes off when the cars off. it as if when the memory off the speedo goes the revometer jumps bavk one place and you can spin the needle with your finger there's no tension there. what would everyone suggest, really need someones help Smile thanks
PostPosted: Fri Jun 24, 2011 3:56 am Up
p**sing in the wind
Is it a non plexed or multiplexed 206 we are dealing with?
jaybooooi
PostPosted: Fri Jun 24, 2011 4:01 am Up
I have no clue what does it need to be multiplexed, it has no alarm Urm its a 1.1 lx model and its 2003 Smile if that's any help to you
PostPosted: Fri Jun 24, 2011 4:04 am Up
Multiplexed then.
What exact fault do you have?
Multiplexed clusters the needles do move down from 0 to a rest position when the BSI goes to sleep.
They also move up from rest to the 0 position when the BSI wakes up.
jaybooooi
PostPosted: Fri Jun 24, 2011 4:09 am Up
Yeah that's right ha ha but when it comes on the needle spins around and goes back to say 7000 revs then the next time it goes off it will shoot back to 5000 there's nothing stopping the needle spin
PostPosted: Fri Jun 24, 2011 4:16 am Up
Start at number 1 & see if the fault is cured, if not move on to number 2, then number 3.
1) Reboot the BSI unit.
2) Check the wiring:
Instrument cluster blue 18 way connector:
Pin 4 - wire 9004
Pin 2 - wire 9005
BSI unit black 10 way connector:
Pin 8 - wire 9004
Pin 10 - 9005
3) Update the BSI software
jaybooooi
PostPosted: Fri Jun 24, 2011 4:32 am Up
I'm a dummy when it comes to things like that , how do you reboot the bsi, and if all them don't work? Ha ha Smile really appreciate your help atm tho thanks
PostPosted: Fri Jun 24, 2011 5:07 am Up
www.206info.co.uk/Forums/search/
