Latest: sparrowdclxvi
Overall: 17139
Online Now [105]:
Visitors: 104
Today: 19741
Total: 113509289
Forums › The Car › 206 Problems › Odd misfire :-/
Odd misfire :-/
sicskate
PostPosted: Fri Jun 24, 2011 11:51 am Up
Trade Rating: +13
This only started this evening on my 138gti
When between 1750-2250 rpm I'm getting a miss fire and a flatspot.
Its not too bad as I can just accelerate through it, but it's a pain as between gear changes it usually picks up at around 2000rpm, so every gear change I'm getting this, unless I'm giving it beans.
Many thanks in advance.
307 1.4hdi Smile
PostPosted: Fri Jun 24, 2011 11:53 am Up
Engine managment light on?
sicskate
PostPosted: Fri Jun 24, 2011 12:00 pm Up
Trade Rating: +13
Nope, the bulb only comes on with the ignition on.
307 1.4hdi Smile
PostPosted: Fri Jun 24, 2011 12:16 pm Up
Might be worth checking / replacing the spark plugs first.
Nice set of Bosch super plus plugs are cheap enough.
Hope it aint running NGK's Wink Laughing
roberto.f
PostPosted: Fri Jun 24, 2011 12:18 pm Up
Could be loads of things. Injectors faulty, lambda, coil pack, spark plugs, list goes on..
Jun 09 - Nov 09: Peugeot 106 1.1 Independence
Nov 09 - January 10: Vauxhall Astra 1.6 8v Club
January 10 - June 10: Peugeot 206 1.4 GLX
June 10 - Present: Peugeot 206 2.0 GTi
sicskate
PostPosted: Fri Jun 24, 2011 12:21 pm Up
Trade Rating: +13
Yup, I'm aware it could be a number of things.
Luckily I'm quite handy with tools, I mainly wanted to rule out a clutch issue as it's always between the same rpm.
307 1.4hdi Smile
sicskate
PostPosted: Fri Jun 24, 2011 2:07 pm Up
Trade Rating: +13
Light has just come on Sad
307 1.4hdi Smile
PostPosted: Fri Jun 24, 2011 2:10 pm Up
There will be a fault code stored now Laughing
sicskate
PostPosted: Fri Jun 24, 2011 2:20 pm Up
Trade Rating: +13
Does that mean I have to take it to a garage?
307 1.4hdi Smile
GTINI
PostPosted: Fri Jun 24, 2011 3:54 pm Up
I had a similar problem. My car started to misfire and one of my mates said it might have been my HT leads or spark plugs. So we changed the sparks to super 4's but that didn't solve the problem. My uncle then did a diagnostics and found that an injector was the problem. After a few weeks, the same again, one of the other injectors had gone. Then it misfied again so I had enough, it needed serviced anyway so sent it into puegeot to see what the crack was and they serviced it. I felt stupid after, the sparks plugs wern't tightened so when accelerating they where bouncing out and causing a misfire (wasn't me that change the sparks lol). But the original problem was the injector but thats what can happen so get everything checked. Also maybe check the coil pack, changed it too but it wasn't that lol. Hope that helps a bit.
Get it in, get it out, get it home, get it washed!
sicskate
PostPosted: Sat Jun 25, 2011 3:59 am Up
Trade Rating: +13
Any help?
307 1.4hdi Smile
copey
PostPosted: Sat Jun 25, 2011 4:02 am Up
sicskate wrote:
Any help?
take it a garage, get the fault codes read, then you'll know exactly what todo
02 2.0 hdi d turbo
Rob2859
PostPosted: Sat Jun 25, 2011 4:12 am Up
A decent garage will charge nothing or very little to plug a diagnostic machine in. You may need to get the error log cleared before the light goes out.
jaybooooi
PostPosted: Sat Jun 25, 2011 4:18 am Up
Can I ask what is wrong with running ngk spark plugs?
sicskate
PostPosted: Sat Jun 25, 2011 4:43 am Up
Trade Rating: +13
Hmm, light has gone now, but misfire remains :/
307 1.4hdi Smile
