Posted: Sun Jun 26, 2011 5:33 pm |
When I'm driving around 10 mph and apply gas when needed, I feel an uncomfortable "jump" that feels like something is not mounted correctly from its position underneath and as it slows down, it jumps again. Anyone know about this problem?
Thanks in advance.
Posted: Sun Jun 26, 2011 5:44 pm |
Engine mounts.
Posted: Sun Jun 26, 2011 5:45 pm |
Ive got this problem aswell seems to turn to the right then left off the gas and it goes to the left, i think its the bushes, im going to get it sorted tomorrow so ill let you know what they say about mine
Posted: Sun Jun 26, 2011 5:57 pm |
I was going to get this checked tommorow (hopefully free) I know Halfords do free checks just hope the outcome is not costly over this...
I have also noticed my gear stick shakes like mad in gear 4 particiularly at high revs and sometimes gear 2. I try to avoid these gears when I can because I believe something will dismount...
Posted: Mon Jun 27, 2011 1:00 am |
karimali831 wrote: |
I have also noticed my gear stick shakes like mad in gear 4 particiularly at high revs and sometimes gear 2. I try to avoid these gears when I can because I believe something will dismount... |
Definitely engine mounts, my Gearbox/rear mount snapped 2 weeks ago after feeling a horrible shaking/vibration through the gears, cost £150 to repair as it broke the gear linkage too!
| Renault Twingo 1.2 GT TCE, AP Coilovers, 25mm Hubcentric Wheel Spacers (Rear), 16" Speedline Turini Alloy Wheels, Renault Sport Cup Spoiler,, BMC F1 Panel Filter, Forge Dump Valve, Front Mounted Intercooler, K-Tec SS Cat-Back Exhaust System, K-Tec Decat Pipe, K-Tec Remap. 136.6 BHP 154.3 lbs/ft. | |
Posted: Mon Jun 27, 2011 1:20 am |
Think i have the same problem. So does anyone know where to get upgraded engine & gear box mounts from?
Posted: Mon Jun 27, 2011 1:25 am |
Posted: Mon Jun 27, 2011 1:33 am |
Cheers JE_180 ill get them order straight away before the problem gets worse. cheers again buddy!
Posted: Mon Jun 27, 2011 1:38 am |
Slickrikk wrote: |
Cheers JE_180 ill get them order straight away before the problem gets worse. cheers again buddy! |
No problem mate!
Posted: Mon Jun 27, 2011 1:39 am |
Trade Rating: +59
Do you really think Halfords employees will be able to tell you what's wrong with your car? take it to a proper garage if you value knowledge.
| '98 Nile Blue 306 GTi 6
'04 Obsidian Black 206 GTi 138 | |
Posted: Mon Jun 27, 2011 1:44 am |
G. wrote: |
Do you really think Halfords employees will be able to tell you what's wrong with your car? take it to a proper garage if you value knowledge. |
LOL, i've only just read that halfords thing... f*** taking a car there for a diagnostic :/
Posted: Mon Jun 27, 2011 2:54 am |
Halfords recently took over Nationwide Autocenters, so its not really Halfords like the shop lol, they are regular garages, its just they use halfords parts.
Any work you undertake as a result of my posts is done so at your own risk | |
Posted: Fri Jul 01, 2011 7:19 pm |
@ Slickrikk: did you get the problem fixed?
Posted: Sat Jul 02, 2011 1:16 am |
I really don't think uprated engine mounts are the answer. Expect a significant reduction in refinement.
Posted: Sat Jul 02, 2011 2:45 am |
Edward wrote: |
I really don't think uprated engine mounts are the answer. Expect a significant reduction in refinement. |
that's because they can't find stock engine mpunt online
