Online Now [1293]:
Visitors: 1292
Today: 463642
Total: 153858097
Forums › The Car › 206 Problems › Rear brake load sensing valve
Go to page Previous  1, 2
PostPosted: Tue Apr 19, 2011 7:47 am Up
Got the whole valve unit for £16 off egay cheers for the help guys Smile
LoopPiper
PostPosted: Mon Jun 27, 2011 4:09 am Up
My 206 failed the MoT as well with the rear brake load sensing valve.
Got it repaired and the MoT for about £300.
My problem being now my rear LHS R'Brake (Drum) is now stuck on.
R'RHS seems fine?! I think.
I called the garage and they say it has nothing to do with what they have fixed and im sure there will be more exspense.
Do you think that the rear brake sensing valve can malfinction and seas the R'LHS drum?
vfdfyu
PostPosted: Mon Jun 27, 2011 8:00 am Up
You will most likely find the friction material has come of a shoe & jammed the drum up.
Drum of & check the shoes, also check the brake cylinders aint leaking.
Page 2 of 2
