Posted: Mon Jun 27, 2011 8:50 am |
Question to all those who have had their cambelts changed on the gti 138
Has anyone noticed a leak of coolant after their cambelt has been changed but not seen any difference in the engine i.e. overheating, not responding properly?
Did see something on here from a fellow info member who had to replace a part after their cambelt change but can't find the thread or if it is the same problem I have.
Posted: Mon Jun 27, 2011 8:51 am |
most people have cambelt and water pump changed at the same time bud
Water pump gasket leaking?
Posted: Mon Jun 27, 2011 8:58 am |
I had my water pump changed with the cambelt and soon after noticed the leak on the drivers side mid engine, it's def coolant because I tasted it, yuck!
Posted: Mon Jun 27, 2011 8:59 am |
Genuine Peugeot / Citroen part from a main dealer?
MattyP wrote: |
I had my water pump changed with the cambelt and soon after noticed the leak on the drivers side mid engine, it's def coolant because I tasted it, yuck! |
Posted: Mon Jun 27, 2011 9:02 am |
take it straight back bud, sounds like they done a s**t job
Posted: Mon Jun 27, 2011 9:17 am |
MrBSI wrote: |
Genuine Peugeot / Citroen part from a main dealer? |
honestly can't say, the garage may have got it from either the following
eurocarparts
GSF
Peugeot
Posted: Mon Jun 27, 2011 9:39 am |
should be covered under warrenty if its a fault in a part fitted or the quality of the work
see what the garage that did the work say most places will offer to sort it f.o.c. if they believe they are at fault
