Latest: dreyfalon
Overall: 17121
Online Now [263]:
Visitors: 262
Today: 153239
Total: 97679478
Forums › The Car › 206 Problems › Air-con
Air-con
Ben.M
PostPosted: Mon Jun 27, 2011 10:47 am Up
How much would it cost to get my air-con re-gassed???
It used to work but then the car was sat around for nearly a year without the A/C being used and when I push the button you can see a slight drop in the revs so i'm pretty sure its all working but just needs gas Razz
Thanks,
Ben.M
PostPosted: Mon Jun 27, 2011 10:49 am Up
would say between £60-100 depending on where you take it
thats assuming its just drained out over time and just needs a straight forward re-gas
if it is a leak thats causedit then the cost starts to esculate quite rapidly :/
PostPosted: Mon Jun 27, 2011 10:51 am Up
I thought regassing was about £30 Laughing
furryhobnob
PostPosted: Mon Jun 27, 2011 10:53 am Up
Me too, I got told it's about £28 to re/gas my aircon
PostPosted: Mon Jun 27, 2011 10:54 am Up
depends how its done Very Happy
we charge £70 at work but that is a full drain, leak checked then if passes is re-gassed with the correct amounts of gas and oil (with combined uv leak detection dye to help easily pinpoint future leaks) and a pollen filter change
Ben.M
PostPosted: Mon Jun 27, 2011 10:58 am Up
Ok thanks guys, just hoping Lee and hobnob are right Wink Drove into college today and was so tempted to stick my head out of the window like a dog, it was that hot in the car even tho the fan was on cold and setting 4, need to get it sorted asap,
thanks again,
Ben.M Smile
Ste
PostPosted: Mon Jun 27, 2011 11:02 am Up
Staff - Ste
Most places I've seen for a good aircon recharge charge around the £70 mark.. Your backstreet "Low Pressure" fillers will do it for about £30-45ish, A true aircon regas removes the old gas along with moisture, checks for leaks and then refills using both the high and low pressure pipes.
The Cars:
brad-morris
PostPosted: Mon Jun 27, 2011 11:11 am Up
Ste206 wrote:
A qualified aircon regas removes the old gas along with moisture, checks for leaks,evacuates the system and then refills using both the high and low pressure pipes.
Gas doesnt just dissapear as said by other members its because of a leak.
Ste
PostPosted: Mon Jun 27, 2011 11:19 am Up
Staff - Ste
true / qualified - Meh lol
They do actually advise you get them regased every 2 years anyway, aircon loses it's cooling effectiveness over time.
The Cars:
brad-morris
PostPosted: Mon Jun 27, 2011 11:34 am Up
Yeah i can understand that with such a small amout of refrigerant in, just be careful there are MANY aircon cowboys out there. best to check they are F-Gas/Refcom qualified (Y)
PostPosted: Mon Jun 27, 2011 11:35 am Up
As long as its filled up and works, who gives a s**t Laughing
brad-morris
PostPosted: Mon Jun 27, 2011 11:39 am Up
Me, if they overcharged/undercharged the system and damaged any of the components
PostPosted: Mon Jun 27, 2011 11:40 am Up
Then they'd have to pay for it...
PostPosted: Mon Jun 27, 2011 11:41 am Up
I have heard of a certain fast fit tyre place that does aircon damaging the system of a Ford Galaxy by putting to much gas in Laughing
brad-morris
PostPosted: Mon Jun 27, 2011 11:57 am Up
Yes, so why not go to a qualified engineer rather than the " fill it up aslong as it works " approach
