Posted: Tue Jun 28, 2011 9:46 am |
They found nothing apart from a badly wired up 02 sensor. They were getting many errors including intermittent ECU fault, a number of injector errors, Knock sensor error and other but I can't remember what he said. Not been to pick the car up yet. The car then stopped giving errors like it did with me before. He said the BSI is probably had it.
Posted: Tue Jun 28, 2011 9:56 am |
You're non-plexed right?
Very rare for a non-plexed bsi to just go if you haven't been tampering with it
Posted: Tue Jun 28, 2011 10:06 am |
Thats right. Well what do you think lee? I have tried everything.
Posted: Tue Jun 28, 2011 10:16 am |
Just seems strange that all the faults are in the engine ECU but yet they are saying its the BSI
What they scanning it with?
Posted: Tue Jun 28, 2011 10:30 am |
I don't know tbh. He said BSI maybe he was mistaken? What control does the BSI actually have over the ECU?
Posted: Tue Jun 28, 2011 10:34 am |
The BSI contains the IMMO and that's it.
Posted: Tue Jun 28, 2011 10:42 am |
Its f****d!
| 4.0 V8 S-Type Jaguar
Image removed due to size | |
Posted: Tue Jun 28, 2011 10:45 am |
Has it been scanned with Peugeot Planet?
If the garage reckon the BSI unit is defective id be tempted to speak to BBA & send them both the engine ecu & the BSI unit for testing / quote to repair.
www.bba-reman.com/uk/index.aspx
Posted: Tue Jun 28, 2011 10:50 am |
If the BSI only controls the IMMO in the car then it should be fine, as the IMMO is working otherwise the car wouldn't start and they wouldn't be able to access the engine ECU.
If it's only engine based things at fault then it will either be some sensor/s or the engine ECU
Posted: Tue Jun 28, 2011 10:52 am |
namgaj wrote: |
Its f****d! |
Than you for that useful diagnosis
Maybe he was mistaken and was talking about the ECU, he didn't really sound like he know what he was doing tbh. Will have to call again tomorrow. I might send the ECU off. How much to BBA charge? I can get hold of a band new ECU for £100, not sure if its blank or just needs coding.
Posted: Tue Jun 28, 2011 10:53 am |
Wonder if the engine ecu connectors are still covered in the w**ky silicone grease Peugeot used on the production line
Might be worth spraying some electrical contact cleaner spray on the connectors.
Posted: Tue Jun 28, 2011 10:54 am |
New ECU needs to be unlocked or come with the matching BSI and transponder
Posted: Tue Jun 28, 2011 10:55 am |
Lee wrote: |
If it's only engine based things at fault then it will either be some sensor/s or the engine ECU |
A dodgy battery spazzed me electrics and blew my windows and central locking but I do not think its related as it was already on 2 cylinders. Not bothered trying to fix those yet.
Posted: Tue Jun 28, 2011 11:07 am |
Lee wrote: |
New ECU needs to be unlocked or come with the matching BSI and transponder |
How much is unlocking? The one i can get is from a pre-plexed i suppose it different though?
Posted: Tue Jun 28, 2011 11:10 am |
Is it currently on a car that will start?
If so, then I'll tell you how to unlock it for free
