Posted: Wed Jun 29, 2011 2:16 pm |
My washers were hardly working on Monday. Thought reservoir must be low so topped up, and now rear washer is working fine, drivers side front barely gives enough water to reach the screen and passenger side gives nothing!
Took sound proofing panel off inside of bonnet today, and difficult to see what is going on as the washer tubes are black, not clear as I expected, but there is no sign of a leak on any if the joints. Pump is working fine as it reaches the rear screen OK. Any suggestions what to try next please?
Posted: Wed Jun 29, 2011 2:18 pm |
Trade Rating: +45
The hose could possibly be trapoed or bloked. Or the washer jets could be blocked. Have u tried clearing thm with a needle
| PAST -2008 Vauxhall Astra VXR / 2002 pug 206 GTI
Now have my 106 GTI track car
TEAM - I HATE FACEBOOK | |
Posted: Wed Jun 29, 2011 2:19 pm |
I've got the mist type jets, not the older nozzle ones, so not sure about sticking a needle in them?
Posted: Wed Jun 29, 2011 2:21 pm |
Trade Rating: +45
Na im not sure if you can with the mist jets. If the worst comes to the worst juat replace the hose. Thts what i did as mine stoped working
Posted: Wed Jun 29, 2011 2:25 pm |
Try taking the washer jets off then trying the washers again if water comes out of the pipe its the jets that need changing
Posted: Wed Jun 29, 2011 3:01 pm |
Werdnal wrote: |
Took sound proofing panel off inside of bonnet today, and difficult to see what is going on as the washer tubes are black, not clear as I expected, but there is no sign of a leak on any if the joints. Pump is working fine as it reaches the rear screen OK. Any suggestions what to try next please? |
Whats the sound proofing panel? My engine is quite loud in my car!? :/
Posted: Wed Jun 29, 2011 3:16 pm |
mine has done the exact same thing today lol hmmm
Posted: Wed Jun 29, 2011 3:18 pm |
Norvvv wrote: |
Werdnal wrote: |
Whats the sound proofing panel? My engine is quite loud in my car!? :/ |
Lining underside of the bonnet there is a thick soundproof panel. Mines a 2.0HDi, so I assume its standard on a diesel.
Posted: Wed Jun 29, 2011 4:04 pm |
Werdnal wrote: |
Norvvv wrote: |
Werdnal wrote: |
Lining underside of the bonnet there is a thick soundproof panel. Mines a 2.0HDi, so I assume its standard on a diesel. |
my 1.4 hdi has one too lol i've seen a lot of 206s without them
i thought it was a heat shield though
Posted: Wed Jun 29, 2011 5:29 pm |
Trade Rating: +36
Antknee wrote: |
Werdnal wrote: |
Norvvv wrote: |
Werdnal wrote: |
i thought it was a heat shield though |
There is the correct description. Not much point in soundproofing the engine really.
Posted: Wed Jun 29, 2011 6:00 pm |
I took off the jets and detached all the hoses and left them sitting in a little tub of hot water and bleach for a while and then squeezed the hoses, you wouldn't believe the s**t that came out! Put it all back together and it worked a treat!! 15 min job!
Posted: Wed Jun 29, 2011 6:10 pm |
if your phase two nozzles are blocked remove the pipe on the back and blast some compressed air down them if you can as it'll force the crap out the back, even a jet of water will remove the dirt
