Latest: flipflap
Overall: 17140
Online Now [421]:
Visitors: 420
Today: 16442
Total: 113816653
Forums › The Car › 206 Problems › cooling fan
cooling fan
scousemouse
PostPosted: Thu Jun 30, 2011 4:25 am Up
so far repaired fan wiring the low speed fan comes on with air con high speed fan works replaced both green and blue sensors and low speed fan resistor done 400 miles on motorway non stop and car does not over heat but when you sit in traffic for about 45 seconds you can see the temperature guage rise to about 95 degrees and then the stop light will come on along with the warning beeps the high speed fan will then come on and the temperature will drop to abaout 90 degrees as i said the car isn't overheating is it possible to change the temperatur at wich the fan comes on thanks
if you can\'t fix it with a hammer your problem\'s electrical
PostPosted: Thu Jun 30, 2011 4:27 am Up
Punctuation is needed for me to be able to read that Laughing
GregorG
PostPosted: Thu Jun 30, 2011 4:30 am Up
What He Said
scousemouse
PostPosted: Thu Jun 30, 2011 4:38 am Up
i asked for advice not abuse if you can't be bothered to read it then dont be a d**k
Big_Rich180
PostPosted: Thu Jun 30, 2011 4:52 am Up
Its hardly abusive, your just being asked to write to a normal standard of english.
They are not giving you abuse here so there is no need to go on the personal attack.
Your OP is very hard to read so it would be best to go over it again and make it a bit clearer and then you may get the help you need.
Norvvv
PostPosted: Thu Jun 30, 2011 5:05 am Up
Give him some credit he's scouse. Laughing
No I don't think you can change the temp the fan comes on. Not easily anyway.
2001 1.4lx
PrePlexed 5 door.
PostPosted: Thu Jun 30, 2011 5:07 am Up
You could always wire in a switch.
PostPosted: Thu Jun 30, 2011 5:38 am Up
somethings wrong there. The lowspeed fan should come on around 93 without any warning messages so clearly there's an issue somewhere. Wouldnt it be in the cars ECU that determines what temperature the fan kicks in? I doubt this would have been altered by someone else?
MrrNoName
PostPosted: Thu Jun 30, 2011 6:29 am Up
it depends on what engine you have but I dont think the stop light should come on for overheating at 95, it should come on when hotter
scousemouse
PostPosted: Thu Jun 30, 2011 8:23 am Up
thanks for the replies. i can watch the temp rise in front of me in a matter of seconds and if it was not for the stop light there is no issue as the car does not overheat. I am really getting fed up with this , i just thought maybe somebody else has had the same problem
Abzynthe
PostPosted: Thu Jun 30, 2011 8:25 am Up
East Area Rep - Abzynthe
My high speed fan has only ever come on once Laughing and that was after i turned the ignition off. Lasted about half an hour Shocked
My low speed fan is near enough constantly on with the engine running.
scousemouse
PostPosted: Thu Jun 30, 2011 8:32 am Up
thanks does your car have air con if so then this could be the problem as mine only runs with air con on. Also does your low speed fan run from near eneough cold
Abzynthe
PostPosted: Thu Jun 30, 2011 8:34 am Up
Yeah, I have aircon, but there's no gas in it so its never used. My low speed runs as soon as I start the engine and the high speed doesnt kick in at all or very rarely after im parked up.
scousemouse
PostPosted: Thu Jun 30, 2011 8:37 am Up
thanks a lot mate maybe my problem is my low speed fan not coming on and allowing the temp to rise .could you tell me roughly what temp your car runs at around town.
I did a run of 400 motorway miles yesterday and the car sat just below 90 degrees but as soon as i got into town my temp rises in front of my eyes
