Latest: dreyfalon
Overall: 17121
Online Now [207]:
Visitors: 206
Today: 101215
Total: 97504871
Forums › The Car › 206 Talk › Sports or high-flow cat?
Swardy
PostPosted: Thu Jun 30, 2011 8:51 am Up
I'm just curious to know if anyone has a sports cat or high flow cat on their gti or gti 180 and if it makes much difference?
They are ruddy expensive, are they worth it?
or has anyone gone the whole hog and just got a cat replacement pipe? again, what sort of difference does it make?
Swardy
206 gti (138), Superchips remap, K&N panel filter, Scorpion cat back
Big_Rich180
PostPosted: Thu Jun 30, 2011 8:55 am Up
The 180 has a sports cat as standard IIRC.
Regarding de-cats have a quick search as it has been covered alot.
Swardy
PostPosted: Thu Jun 30, 2011 8:56 am Up
ok, cheers mate. Sorry, at work and was being a bit lazy.
PostPosted: Thu Jun 30, 2011 1:05 pm Up
I find it very hard to believe that any standard road car has a sports cat as standard, especially a GTi 180 - despite what rumours on here suggest. Has anybody any pictures of the cat internals?
If you are going for a full system then fit one, if you are going for a custom build Powerflow type then don't bother because the non mandrel bends in the exhaust will create restrictions in the exhaust anyway. A sports cat on a Powerflow type exhaust is effectively the same as polishing a turd.
Swardy
PostPosted: Thu Jun 30, 2011 4:46 pm Up
I've got a Scorpion full cat back on my gti 138 mate.
Hmm, didn't know that. I'm curious to know if anyone's actually fitted one and to what avail.
Annoyingly Scorpion don't do a sports cat for the gti, janspeed do though.
Danw_VVT
PostPosted: Fri Jul 01, 2011 12:55 am Up
im gettin g a hi flow! Very Happy
JE_180
PostPosted: Fri Jul 01, 2011 1:30 am Up
I've seen them when I had my Race/Sports Cat fitted to my 180, and in comparison there's alot more material inside which is quite compacted unlike the Race/Sports Cat which you can see right through Smile
and to the OP, yes it does make a difference, I wouldn't go back to a OEM Cat after this... The engine feels pokier and free, and it sounds immense... pops and bangs a lot Smile
Swardy
PostPosted: Fri Jul 01, 2011 1:40 am Up
Oh, I want one now!! damn you!! Sad
Any recommendations on which one or where's best to get them from? (mine is a gti 138)
JE_180
PostPosted: Fri Jul 01, 2011 1:41 am Up
I got one from Longlife Exhausts, they custom fit them to your car, mine was £300 drive in drive out.
Swardy
PostPosted: Fri Jul 01, 2011 1:46 am Up
I'll look into it. Cheers dude!
JE_180
PostPosted: Fri Jul 01, 2011 1:56 am Up
No problem Smile
