Online Now [321]:
Visitors: 320
Today: 125946
Total: 156232263
Forums › The Car › 206 Problems › Airbag light
Airbag light
danart22
PostPosted: Tue Jun 28, 2011 9:25 am Up
Hi all,
Apologies if this is mentioned somewhere, did a search and didnt come up with much.
Have a 51 plate 206 1.9d, just got in to come home from work and the airbag light came on, it beeps once about thirty seconds after and just stays on. Any one got any ideas what may be kaput?
Thank you!
51 plate 1.9D
PostPosted: Tue Jun 28, 2011 9:27 am Up
Same topic came up yesterday
Lee wrote:
Get it on a diagnostic scan. That will tell you the airbag fault as well
Wrote a full thread on how to manually trace a airbag fault
206info.co.uk/Forums/v...irbag.html
Abzynthe
PostPosted: Tue Jun 28, 2011 9:29 am Up
East Area Rep - Abzynthe
reading this, Ive just thought, When i plugged in the passanger airbag switch (I dont have a passanger airbag) it did the same beeping, I disconnected it, but the light stays on for about 10 seconds after the cars started then goes off, is that normal. Also would that store a fault code?
danart22
apologies just spotted that
51 plate 1.9D
PostPosted: Tue Jun 28, 2011 10:18 am Up
Why connect a switch up for equipment you dont have?
The airbag ecu is smart enough to see the switch & also smart enough to see the passenger airbag is missing Wink
Abzynthe
PostPosted: Tue Jun 28, 2011 10:49 am Up
I did it by mistake, I just plugged everything in when putting the new instrument panel on.
danart22
PostPosted: Wed Jun 29, 2011 3:11 pm Up
Further to my original post took the car along to the garage today and had a scan...
Came up with the following and was wondering if anyone could make any sense of them?
802 - Ignition circuit drivers side airbag stage 2 - open circuit
06F- Airbag passenger side airbag deactivated
Now it threw up these codes as well but the guy at the garage seems to think these may be old codes not cleared?
042 - Driving speed signal not plausible
P0215 - Main relay defective
0110 or d cant read his writing - Right trn signal indicator faulty
01b7 - Brake switch faulty
The guy says i need a new comm2000 and it will cost about 200 plus 43 an hour labor and it will take about two hours.that sound right??
Have no idea what the above codes mean but i guess the top ones relate to the comm2000 and the others are old codes as i think i would know if my main relay was defective! and my turn signals all work fine.
Oh he also said that even with a new com2000 the airbag light might not go off and i may need a new airbag too.. anyone help decifer this foreign language for me??
51 plate 1.9D
PostPosted: Wed Jun 29, 2011 3:33 pm Up
Robbing you blind there. A com takes under an hour to replace, and they don't cost nowhere near that much
Is your's even plexed? 1.9 plexed engines are uber rare
Did any of the engine fault codes return once he cleared them?
danart22
PostPosted: Wed Jun 29, 2011 3:51 pm Up
not sure mate as im not sure if he cleared them. Im guessing mine is a MUX as it has the radio stalk thingy??
Not sure of any other way of finding out it its plexed or non plexed.
51 plate 1.9D
danart22
PostPosted: Wed Jun 29, 2011 3:53 pm Up
Think my car was produced in like the very first month of MUX cars Sad
51 plate 1.9D
PostPosted: Thu Jun 30, 2011 8:37 am Up
About 12 mins to change a com2000 if im in a hurry Laughing
PugJH
PostPosted: Thu Jun 30, 2011 8:54 am Up
Done it in 10 HA.
Think i need a code reader for my new car, no sure if its the com2000 unit thats faulty on mine, altho it was replaced before by pug.
WIP: Black 1.6 16v XSi
Beauté Noire
PostPosted: Thu Jun 30, 2011 8:56 am Up
PugJH wrote:
Done it in 10 HA.
Peugeot Planet Wink
PugJH
PostPosted: Thu Jun 30, 2011 9:26 am Up
Soon, very soon, get ya wallet out and we'll talk
Beauté Noire
PugJH
PostPosted: Thu Jun 30, 2011 9:31 am Up
Covering all the angles with that one?
Beauté Noire
